- Thank you received: 9
'80 kz750 transmission manual
- retterath
11 Feb 2010 05:06 #347695
by retterath
'80 kz750 transmission manual was created by retterath
So, I'm looking at a broken sprocket shaft as the result of an over-enthusiastic chain tightening.:blush:
What's a good book to guide me through the process of replacing the gear set?
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
11 Feb 2010 06:39 - 11 Feb 2010 06:43 #347706
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic '80 kz750 transmission manual
Much easier is to replace the motor, or even just the bottom end.
To replace the trans output shaft you will need to split the cases; it is alot of work; but not to hard if you have the proper tools and a decent work area.
If you are intrested I have a 750 bottom end that seems solid (I bought the engine for the head and cyliners). You could have it if you want it. I live in Maine but could meet you anywhere between Halifax Nova Scotia and Rochester NY.
::Edit:: just say your location in your profile, I don't think we will be able to link up :laugh:
If you are going to repair your motor you will really need a FSM (factory service manuel)
1977 kz650 c1
Last edit: 11 Feb 2010 06:43 by hardr0ck68.
