- Thank you received: 337
Is this piston reusable?
- bountyhunter
08 Feb 2010 23:35 - 08 Feb 2010 23:35 #347359
by bountyhunter
Replied by bountyhunter on topic Is this piston reusable?
polkat wrote:
Where measured? I remember my pistons (and everyone I have seen) have a taper from top to bottom with the skirt (bottom) being the widest so it has the tightest fit to the cylinder and the top having a lot more clearance.And the clearance (which should be .040~.067mm) is correct at about .050 all around the piston.
Last edit: 08 Feb 2010 23:35 by bountyhunter.
- polkat
- Thank you received: 1
09 Feb 2010 08:51 #347407
by polkat
Replied by polkat on topic Is this piston reusable?
yea, it was measured at spots around the bottom as the book suggested. Surprisingly, this piston had the best compression of the set. I can't afford a new piston right now (unemployed and poor) so I'll try the cleanup and see if it works for a while.
