- Thank you received: 1
Is this piston reusable?
- polkat
This piston is scuffed on three sides 90 degrees apart (but not on the forth side). Oddly, the bore shows nothing in these areas (which measure out fine). The skuffing on the piston looks bad, but won't catch a fingernail. I'm poor, and so I'm wondering if I can reuse this piston? Or should I look for a reusable used one (anyone got one)?
Thanks!
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- BSKZ650
- Thank you received: 14
new set of oversize pistons and rings, and bore cyls out, build it right the first time.
77 ltd1000, current rider
76 kz900, just waiting
- 9am53
- homebrew, and some bbq
- Thank you received: 3
www.z1enterprises.com/SearchResult.aspx?All=True&KeyWords=impk
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- polkat
Surprisingly, as I said, there are no markings in the bore! And the clearance (which should be .040~.067mm) is correct at about .050 all around the piston. Also, the scuffing cannot be felt with a finger. I can't afford new pistons (let alone a single one), so I was wondering about reusing it.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kpier998
www.swaintech.com/store.asp?pid=10971
One of the guys on another forum mentioned this place some years ago. Maybe it would be worthwhile to contact them and send a pic of that piston to see what they can do. For instance, it is only 15 to 20 bucks for the skirt coating.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- hardr0ck68
- Who put the what in the where?
This is my auction, those pistons are in great shape. I also have the cylinder sleeves they were used in (however the sleeves have been removed from the block).
I would be saving these pistons for spares if I did not need the space.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- nads.com
- Thank you received: 20
- otakar
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...e=STRK%3AMESELX%3AIT
The only problem is that yours are for a 650 and his are a 750.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
