New to site! hoping to find some help!
- ntandro
07 Feb 2010 20:44 #347174
by ntandro
New to site! hoping to find some help! was created by ntandro
Hey everybody. Im having some problems on a 1978 kz 1000. The starter is grinding when the motor warms up and is giving me a very hard time tuning. Ive researched and i hear alot about a starter clutch. Im assuming thats thre one way gear inside the left crank case. That seems to be ok. What ive noticed was where the starter meets the middle gear (in between crank and starter) looks as if it was worn out. My idea was the pin that holds that gear in place to align it with the starter has too much play in it. The casing dows not seem to hold that gear back so it jumpes off the starter. any ideas? Also there is a bit of oil inside that casing? new crank seal? Any help would be very appreciated.
- MFolks
- Thank you received: 540
07 Feb 2010 20:53 #347175
by MFolks
Replied by MFolks on topic New to site! hoping to find some help!
Will this help?
Over Running Starter Clutch Repair On the Older, Bigger 4’S
1. When preparing to repair the starter over running clutch have a few items on hand:
A. New alternator cover gasket.
B. New springs (3).
C. New spring caps (3).
D. New rollers (3).
2. If possible, put the motorcycle on the center stand and tilt to the right to reduce the oil volume in the alternator cover.
3. Place an oil catch pan under the left side of the engine to collect what small amount of oil that will escape when the alternator cover is removed.
4. Remove the foot shifter lever, left foot peg assembly and the sprocket cover.
5. Some Kawasaki’s have socket head cap screws(Allen type) and others may have fasteners with a Phillips type. If the latter is there, a # 3 bit seems to work the best for removal.
6. Remove the alternator cover and take care with the three wires coming from the alternator stator. These are the voltage supply wires for the motorcycle. Rest the cover on some newspaper or rags to prevent damage.
7. The magnetic Rotor or flywheel will probably require a removal bolt or puller. NOTE, SOME ENGINES HAVE LEFT HAND THREADS ON THE ROTOR!!
8. The over running clutch is bolted to the back of the rotor with three Allen head fasteners.
9. Separate the rotor from the over running clutch and inspect for damage in the springs, rollers, and spring caps. Replace any worn parts.
10. Re-assemble in reverse order taking care when re-installing the Alternator cover not to pinch any wires. If the cover will not re-install without force, check before any damage occurs.
B. New springs (3).
D. New rollers (3).
- ntandro
07 Feb 2010 20:59 #347176
by ntandro
Replied by ntandro on topic New to site! hoping to find some help!
i did all of the above. It seems to be the gear slipping off the starter. Not sure what the fix is.
- MFolks
07 Feb 2010 21:21 #347178
by MFolks
Contact Jeff Saunders at
www.z1enterprises.com
he knows a lot about the older Kawasaki's.
Do you have a shop manual? it will help in finding out what part is worn.
Some engine builders websites:(they may have a repair for your engine problem)
www.aperaceparts.com
www.bore-tech.com
www.flowbenchtech.com
www.fastbygast.com
www.grccranks.com
www.schnitzracing.com
www.valleyspeed.ca/services.html
www.carolinacycle.net/index.php?option=c...ex&Itemid=3&catID=84
www.bore-tech.com
www.fastbygast.com
www.grccranks.com
- timebomb33
- Thank you received: 10
07 Feb 2010 21:26 #347179
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic New to site! hoping to find some help!
if its cocking to 1 side that much it sounds like the holes for the drive gear shaft may be ovalled out .
- Kawickrice
- Thank you received: 18
08 Feb 2010 05:54 #347205
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic New to site! hoping to find some help!
ntandro wrote:
My rotor was loose one time and the starter gear would not mesh right. I pulled the cover numorous times until I got it figured out. This might not be your problem but it is worth a look
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
