A/F Ratio Meter via OMR
  • T_Dub
  • T_Dub's Avatar
Re: A/F Ratio Meter via OMR
09 Feb 2010 10:12
#347413
The engine will be more rich under load. At a given RPM, the more you have your carb slide open, the more fuel will be provided. At this specific RPM, the engine will only flow so much air(give or take a little based on how open the butterfly is). And under load, you need more fuel, so you will open that carb slide more.
The reason why the engine leans out at cruise is because it needs very little power to maintain that cruising speed. So the throttle doesn't need to be opened very much, but you're still at a relatively high RPM, flowing lots of air.
Basically I just described how it would be if you negate the effect of the throttle body slide. But thats the easiest way I can think of to explain it.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • DoubleDub
  • DoubleDub's Avatar
09 Feb 2010 10:33
#347415
That makes sense to me.
  • loudhvx
  • loudhvx's Avatar
09 Feb 2010 11:36
#347423
Very well said. That's exactly what the tests show too.
Same throttle position- cruising in higher gears gives lower RPMs and richer AFR.
My carbs are mechanical slides, so there's no second guessing how far open the carbs are.
Also, by the same token, if you are at high RPM and slowly close down the throttle while coasting (and slowing) the AFR goes very lean, which is why if your carbs are too lean, you get the backfires when you close the throttle.
(Not to be confused with the backfires due to the air injection system equipped on the later bikes.)
  • larrycavan
  • larrycavan's Avatar
09 Feb 2010 15:51
#347448
For a carbureted engine, the A/F at any given RPM is going to be the end result of the pressure drop across the valve in combination with the internal jetting components of the carb.
Load plays into this only from the perspective of how load affects the creation of the pressure drop across the valve.
Increasing loads prevent the engine from spinning up as quickly as it would otherwise. That equals less pressure drop communicated back to the fuel orifices so less fuel is admitted into the mixture.
It's possible to be jetted on the lean fringe and have no audible spark knock under acceleration. Then add a passenger and the spark knock comes to the party...
  • T_Dub
  • T_Dub's Avatar
09 Feb 2010 16:05
#347451
But, generally speaking, you will still be leaner at cruise than under loading conditions right Larry? Discounting acceleration that is.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • PLUMMEN
  • PLUMMEN's Avatar
09 Feb 2010 16:08
#347452
great now my head really hurts,thanks larry! :woohoo:
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
09 Feb 2010 17:34 - 09 Feb 2010 17:37
#347472
loudhvx wrote:
Actually, the AFR numbers go down (meaning richer) as the temperature rises. Given the same settings, the mixture will register richer as the temperature goes up because the gas mixes better and the air is less dense.
That's why theres a tradeoff for guys riding in colder climates. If I jet it to run good in colder weather (40's F), I can notice the power drops off on really hot days (80's F and up).
Actually... if you read my post right, I said the fuel in the AFR goes up (richer)... so I think were both right.
The air number decreases, as you stated correctly :P
I should have said it gets less air, not more fuel, but I guess thats the same :huh:
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 09 Feb 2010 17:37 by TeK9iNe.
  • TeK9iNe
  • TeK9iNe's Avatar
09 Feb 2010 17:42
#347475
BSKZ650 wrote:
ok, now for the stupid question,
I understand the idea of setting the fuel mixture using a O2 sensor, but since the bikes have independent carbs for each cyl, shouldnt this be done on each cyl in order to get the correct mixture for each one rather than taking a "average" of all the cyls.
my thought here is one cyl lean and one rich,this would make the sensor think that its balanced when it is really not.
Also in a lot of dyno cells, they have K type temp senosors on each cyl to aide in balancing the engine.
just a thought.... scary aint it,,,,
Yes, ideally you should have a sensor for each individual carb, but it isn't entirely necessary.
If your plugs all look the same after a few hundred miles, your likely just fine.
If your really worried about it, just get a temp gun and fire it at the same spot on each header after a good ride, if your temps are nice and close, again your fine :)
Cheers! B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • TeK9iNe
  • TeK9iNe's Avatar
09 Feb 2010 17:49
#347479
Thats the perfect excuse I needed!
Sorry baby, but you make it knock! :laugh: :woohoo: :laugh:
Maybe next year! :ohmy: :laugh: :P
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • larrycavan
09 Feb 2010 18:19 - 09 Feb 2010 18:21
#347490
B)
Think about it for a second. What makes the piston demand more air? RPM
Why do carbs with accelerator pumps work better than those without from low RPM acceleration?
Fuel flows [unassisted] because the air pressure changes, [decreases]and the fuel can then move up through the jets and into the port.
The faster the air flows through the carb,[RPM Increasing] the less static pressure in the carb throat [velocity pressure increases but static drops] so even more fuel can flow.
Put your bike in 4th gear and lug it down to 20 MPH. This effecively increases the load on the motor. Then wack the throttle open. Then do that in first gear [effectivelly reducing that load]
Last edit: 09 Feb 2010 18:21 by larrycavan.
  • larrycavan
09 Feb 2010 18:44
#347494
I came on this today by chance on a performance forum I'm a member of. I believe it's from Kevin Cameron but not certain.
Introduction.
Motorcycles have had air boxes holding their air filters for decades. However, in the last couple of decades the purpose of these air boxes has changed quite dramatically.
Originally the air box was just there to keep flying dirt, rain, and bugs from directly hitting the air cleaner. They were simply an attempt to keep the air cleaner a little cleaner a little longer.
In the '70s, the US government started making noise regulations tighter. At some point, the manufacturers realized that the noise from the air intake was part of their problem. They started to look for ways to muffle not only the exhaust, but the intake roar too. Sound waves are pressure pulses in the air. Pistons pull in air on their intake stroke, creating a low pressure pulse in the air box. Then on the compression, power, and exhaust strokes the intake valve is closed and the air box is free to return to atmospheric pressure. These alternating low pressure and normal pressure pulses are sound waves. The manufacturers needed some way to dampen them out.
Your exhaust mufflers are made of a series of open chambers connected to each other by tubes. The exhaust pressure pulses get caught in the chambers and bounce around in them, then have to leak out relatively slowly through the tubes. The math that governs mufflers can also be applied to air boxes: you need a big chamber to hold a bunch of air, and an inlet tube to let air in at a controlled rate.
The air in a box is compressible, so a box is the acoustic analog of a capacitor or spring. Air has mass - about 1kg / cubic meter, about 2 pounds per cubic yard. In a tube, the air moves back and forth as a slug, as long as the frequency of the movement is small compared to (tube length / speed of sound). So, at low frequencies a tube is a mass term. Since the speed of sound is about 1000 feet per second, a foot long tube is equivalent to 1 khz. 10,000 rpm is 160 pulses per second on a V-Twin, so "low frequency" clearly applies on an air box for any snorkel shorter than about 6 feet long. A wire screen is the acoustic analog of a resistor. It slows air motion, converting the energy into heat. The combination of a box and tube is a system with a resonance. Exactly as a child's swing has a resonant frequency, exactly as a ported speaker enclosure has a resonant frequency, so does your air box.
A system at resonance is nearly perfect - there are small frictional losses in any system, but at resonance these are the only losses. Imagine pushing a child on a swing - it takes very little energy to keep her going at the natural frequency of the swing, just a little push each swing is enough. The only thing slowing her down is air resistance and a little friction in the chains. So at resonance, air flows through a tuned air box almost without resistance. This is as close as we can get to a superconductor of air.
A modern engine with valve overlap will naturally have a dip in the torque at about a third to a half the red line rpm. If the air box is tuned to have minimum resistance to air flow at this rpm, the dip in the torque curve will be partially filled in by the ease of pulling air into the engine.
So, your air box is most likely designed to add horsepower in the mid-range. The air box will have little or no effect on peak hp.
Years ago, before airboxes were designed as resonant systems, it used to be popular to cut additional holes in the air box to allow more air flow for high rpm. This is no longer a good idea. Modern air boxes can flow much more air than the engine will ever use. Modern engines have throttle bodies or carburetors with throats that are typically about 45mm in diameter, about 16 sq.cm in area. The inlet snorkel to a modern air box will be roughly 300 to 800 sq.cm - much larger than the throttle body or carburetor throat. The idea that the snorkel makes for a significant impediment to air flow into the engine is questionable at best. Drilling holes to let in more air is exactly equivalent to drilling holes in your speaker cabinets to let out more sound. Removing the snorkel from your air box is the exact same thing as removing the port in your speakers, the tube that's carefully engineered to have just the right diameter and length to reinforce the bass on your speakers at low frequencies. By altering your air box in any significant fashion, you're most likely going to cost yourself three to five hp in the mid range, and gain nothing measurable at high rpms.
Part I: Theory.
Here, from first principles we'll develop the theory of how an air box and an inlet tube form a coupled spring- mass system with a resonant frequency.
air box volume = V
inlet pipe = area * length = A * L
Air Mass = 1.25g / 1000 cc
Atmospheric Pressure = 104kg / cm sec2
PV = nkT (Ideal Gas Law)
If the air in the inlet tube moves X cm into the air box, then the volume of air inside the air box changes to:
V' = V + AX
Since Boltzman's constant and the air box volume don't change, that leaves only the temperature and the pressure. The gamma for air is 1.4, so
T' / T = (V' / V)^.4
T' / T = (1 + AX/V)^.4
We'll presume AX/V is small, so (1 + AX/V)^.4 = 1 + .4AX/V
The number of atoms in the air box changes to n' = (1 + AX/V)n. So, the new pressure is:
P'V = (1+AX/V) nk (1+.4AX/V) T
P' = (1 + AX/V) (1 + .4AX/V) P
P' = (1 + 1.4 AX/V) P
Now we can find the spring constant of the air box, K:
Force = Pressure*Area = Kx
Kx = 1.4 AX/V * A * 104 kg cm / sec2
K = AA/V * 146 kg / sec2
The mass of air in the inlet tube is
M = AL * 1.25g / 1000
The resonant frequency w, in radians per second, of a spring-mass system is:
w = sqrt( K/M )
= sqrt( AA/V * 146 kg / sec2 * 1000 / 1.25g AL )
= sqrt( A/VL * 146*1000*1000 / 1.25 sec2 )
= 1000 sqrt( 116.5 A/VL ) / sec
The resonant frequency is w / 2pi, and the resonant rpm is 30 * number of cylinders * f. For a V-twin, rpm = 60 * f.
f = w / 2pi = 160 sqrt( 116.5 A / VL )
resonant rpm = 4775 sqrt( 116.5 A / VL ) (single cylinder)
resonant rpm = 9550 sqrt( 116.5 A / VL ) (V-twin)
resonant rpm = 19100 sqrt( 116.5 A / VL ) (4 cylinder)
Part II. Applications.
Here we'll examine a particular design, and see if we can understand the purpose of the design.
On the Suzuki V-Strom, the air box holds approximately 8 liters, about 8000 ccs. There's an inlet pipe which has a 90 degree bend in it. The two sides, inner and outer, differ in length a bit. We'll use their average, the centerline distance, as the length of the pipe. The pipe opening is about 200 square centimeters, and the length is about 20cm. Fortunately, as all these numbers appear inside a square root, our results will not depend on highly accurate measurements. Of course, if you're designing an air box you would want to be quite precise, but we're just trying to understand an existing design, so if we're off by a few percent it won't really matter. We'll also concern ourselves with the flow through the pipe and see if the mach number of the airflow is low enough to ensure linearity.
At 12,000 rpm, the V-Strom's 1 liter motor is pumping 6,000 liters per minute, 100 liters per second. The V- Strom inlet snorkel has an opening of about 200 cm2. 100 liters per second is a column of air 1000 cm 2 wide by 10 meters long, or 200 cm 2 * 50 meters long, so apparently the peak velocity through the inlet tube is less than 50 meters per second. The speed of sound at sea level is about 340 meters per second, so this is about mach .14.
Whenever air flows past something, like the walls of the inlet snorkel, the air touching the walls will stick to the walls and not flow. The air very close to the stuck air will flow, but sluggishly because the nearby air isn't moving. Thus there will be a region of air right next to the tube walls which does not flow easily. This area is called the Poisson stagnation region, named after the French physicist who first described it mathematically. The faster you try to flow air through the tube, the thicker the stagnation region gets. In a narrow tube at extremely high flow rates, the stagnation regions can grow to pretty much fill the tube and the flow through the tube can get slowed quite dramatically. However, mach .14 is not a very high flow rate. This low peak velocity guarantees the Poisson stagnation region on the tube walls will remain thin, and the tube will be substantially open for free flow. We've satisfied the engineers's prayer "Please, God, let it be linear."
The resonant rpm will be 9550 * sqrt( 116.5 A / VL ) = 9550 * sqrt( 116.5*200 / 8000*20 ) = 9550 * sqrt ( 116.5 / 800 ) = 9550 * .38 = 3650 rpm
This number is consistent with the torque dip in a 10,000 rpm v-twin with valve overlap. Remember, we only estimated the volume of the air box and the length and width of the snorkel, so 3650 rpm is just an estimate and is most likely off by a few hundred rpm. Apparently the Suzuki engineers designed an air box which would resonate at the torque dip, thereby giving essentially frictionless airflow at the rpm where the engine was having the most trouble making torque.
If you decided to make substantial modifications to your engine, like high compression pistons, new cam shafts, and re-mapped ignition and fuel injection, you would very likely change the rpm at which the mid-range torque dip happens. In this case, if you can measure the new rpm on a dyno, you could use this information and our formula to decide on a new snorkel length to change the air box resonance to match the new torque dip.
  • keith1
  • keith1's Avatar
09 Feb 2010 19:19
#347496
this is why i didnt go to college and dopes like me pay other people.....:laugh: :laugh: :laugh:
