- Thank you received: 38
Just fired up new top end on my KZ900
- sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- PLUMMEN
- Thank you received: 104
- nebiker51
77 KZ1000 LTD - original owner
79 650xs - street tracker project
91 HD FXLR Custom - original owner
- keith1
- Thank you received: 2
Just fired up my KZ900 after putting fresh rings and a valve job. Got a fuel leak on my carb conncecting tees and am assuming I can get the orings from Z1. I have seen some nice machined metal tees on Ebay also. I have rebuilt and sync. these carbs, but I will have to pull the end carbs off the rack to change these orings before I get to ride. I got a valve job, all new exhaust guides, and seals for around $240.00 from a place in Florida. I also put a 1.75 competition baffle without the packing. Sounds good, but can't ride until I fix fuel leak.
sweet looking bike....hooper do the head work?.....i also run a comp baffle in my v and h without the packing....sounds good...not too obnoxious and really sings at high rpm.......
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- sbc1320
- keith1
- gane
[img][/img] 1977 KZ1000A1
- grumpy56
- Thank you received: 6
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Old Man Rock
- Thank you received: 225
Sweet!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Or existing pieces could be snugged by wrapping the ends with teflon tape (yellow tape supposedly withstands fuel better than the white version).
Click here for Fuel Pipe at Z1E
Good Luck!
[Click on image to enhance view.]
