- Thank you received: 1415
synthetic oil?
- KZQ
- Administrator
Thanks Terry!
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- zoo
- My 75 KZ400
BTW - I rode a bit today in the freezing cold. Carhart bibs, hoodie and all..... It was wonderful. The bike and I are bonding!
Thanks all!
Tammy
Green Sea, SC
Quarter Horses & Iron Horses!
2009 Vulcan 500
1975 KZ400D
- Old Man Rock
- Thank you received: 225
NOTE: Before you do decide to go this way, visually inspect your engine insuring there are NO oil leaks anywhere for synthetic will find it's way there....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- zoro
GHOSTRIDER,1980,KZ1000ST
- Kawickrice
- Thank you received: 18
I buy it by the case and use it in every internal combustion engine I have from cars to lawnmowers and have never had a problem that was oil related in 25 years
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Rickman
If you use a synthetic with friction modifiers, your clutch will slip relentlessly.
with friction modifiers being key word.
I had slip problems using standard car-type 20w50; when I did a change with amsoil synthetic motorcycle-specific it stopped.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- polkat
Then there is the other side; what is the advantage of running synthetics? I've run them in my car, but stopped because I saw no real advantage at that price.
- RonKZ650
- Thank you received: 240
- bountyhunter
- Thank you received: 337
Moly or some kind of Teflon type product. I have used them in my KZ750 and never had a problem with the clutch, I think it is pretty rare that they affect the clutch but it is possible. BTW, oil companies started putting more of that junk in to replace the ZDDP they removed which older bikes really need.Well...lets get right down to it. What is in the friction modifiers and how does it cause problems?
polkat wrote:
They typically say "energy conserving" or similar on them.Further, when looking at the labels of synthetic oils, what do you look for to see if it has friction modifiers? I've looked at the labels of some oils (not Mobil) and they don't say one way or the other.
polkat wrote:
Bikes tear apart the viscosity enhancers in oils that turn the 10W base oil into 10W-40 oil (or turn 10W into 10W-30 or whatever). If the viscosity enhancers go away, you are left with 10W oil. It's because the oil runs through the tranny gears which act like shears to long molecules.Then there is the other side; what is the advantage of running synthetics? I've run them in my car, but stopped because I saw no real advantage at that price.
Synthetic oils require far less visc enhancers to "make the viscosity" of the milti grades so they are not so prone to visc breakdown over time. The viscosity in a standard oil can break down pretty badly in as little as 1000 - 1500 miles. This is one of the reasons syns can safely run a longer change interval.
- polkat
bountyhunter, that all makes good sense and I understand it. I do remember that when synthetics came out there was a lot of talk about how it would make non-leaking engines running regular oil start to leak when switching to synthetic. Had to do with seal and gasket damage from the synthetic. I wrote that off to silly rumours, but...was there anything to it, and why?
- bountyhunter
I think it's one of the synthetic urban myths along with how it won't mix with regular oil and you have to flush the engine to make sure they don't coagulate.:laugh:RonKZ650, wow! That looks like the original '49 Ford engine I took apart last year! man.
And the other myth about how synth is so "slippery" it won't let your engine break in right......
I don't subscribe to any of them. YMMV
- bountyhunter
Probably should mention: most oils sold as "synthetics" are not true synthetics they are just highly filtered dino oil which makes the whole topic even more complicated since a lot of "syn" oil is actually dino oil.
Some idiotic court ruling a while back made it legal for oil companies to call filtered dino oil 'synthetic" even though true synthetic is a man made lube not dino oil.
