finally found out why 810 knocked
  • jordan
  • jordan's Avatar Topic Author
30 Jan 2010 23:02
#345503
well i finally decided to do some work on the 810 while i took a break from the 1000. I pulled the motor out so i could make room for the new bottom end that i will be building from. I decided that since i never did find out where the metal shavings were coming from, or why it was knocking i would split the cases and be certain. It ended up being a rod bearing, actually what is even more odd is somehow one rod bearing made its way under the other. When i got teh crank out, both bearing havles were on the same side of the crank overlapping eachother. How does this happen? The rod was still torqued very tight (i never touched the bottom end when i did the rebuild). You would think the clearances are soo tight that it would be very hard for one bearing to get under the other. The oiling system was fine, atleast the topend was getting oil fine so i think that wouldnt be the issue. The problem did start right after the second trip to the dragstrip, but i never moved the rev limiter on my dyna 2000 past 10,500 rpm ( the motor had gpz head/cams btw) The first pic is the oil pan, the others are the carnage
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: finally found out why 810 knocked
30 Jan 2010 23:06
#345505
Jeez...you don't screw around, do you?!?!??!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jordan
30 Jan 2010 23:19
#345509
haha, well i was home for the weekend and my girlfriend had to work so i had lots of time on my hands. Maybe she should work more often :laugh:
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • Old Man Rock
  • Old Man Rock's Avatar
31 Jan 2010 02:15
#345512
Wholly Crapola! :pinch: :ohmy:
Well, glad you found the problem... Unfortunately as we all have found in our own situations, the only way to truly know is Open Her Up and find the unknown WTF factor....
Sorry to hear it young man but at least you now know...;)
Bright side is though, now you'll be able to fix her up, mend her wounds and get some sleep for you won;t be constantly thinking about it any longer... :woohoo:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • rustedcutlery
  • rustedcutlery's Avatar
31 Jan 2010 02:21
#345513
haha i concur! how man miles were on that bottom end before you did the 810 kit? it looks like the little indent that holds the bearing halves in place let go and the bearing just spun over underneath the other? did you ever wind it up to 10k that weekend?
dont throw that away either, i wanna see that when i get back!
  • Kawickrice
  • Kawickrice's Avatar
31 Jan 2010 03:54
#345520
What does the rod look like? That sucks to spin that bearing after a rebuild. I guess there is some truth to....build the bottom and the top goes or vice versa. Drag racing season is just starting so you have a little time
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
31 Jan 2010 05:25
#345526
Right now, behind my work bench I have a 650 crank that is just in my way, rods and rod bearings still on it. The main bearings I am using... it is the old style bicycle chain cam chain. If you want it it is yours for the cost of shipping.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • Kawickrice
31 Jan 2010 05:34
#345528
This is why this site is so awesome.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • jordan
31 Jan 2010 08:45
#345572
AMEM TO THAT! Thank you very much for the generous offer but i also have a whole new 750 bottom end in the garage that i may just build instead of fixing this one. Also, i have all the pieces for the bottom end in a tote so if anybody needs anything just holler and its yours.
As for the bottom end, it had just under 11k miles on it, i always used 10-40 or 20-50, the rod surface looks pretty clean and not marred up and im sure it could be reused. The other bearings all look fine with no irregular wear, and the rest of the bottom end looked perfectly fine.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • kawsakiman
  • kawsakiman's Avatar
31 Jan 2010 16:25
#345683
hardrock beat me to it.
i was going to offer on up as well since i have both style cranks but it looks like your all set.
and as for why it spun?
the only time i ever seen a car or bike spin a bearing like that is from over reving the motor.
a lot of people think it's hp and torque that kills connecting rods and bearings when it usually engine speed.
either that or lack of oil which you said was fine.
quit flogging that poor girl so much!
who am i kidding?
most of us flog them once in awhile :P
that's why we build bigger instead of stock.
  • jordan
31 Jan 2010 17:01
#345695
who am i kidding?
haha, yes! Everything has to break sometime, thats racing. i guess ever since the new topend was on it really had a hard life. 90% of the time it was running it was getting ran HARD. Practicing launches for the dragstrip, running it up to redline, and just really squeezing every ounce out of her.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • gane
  • gane's Avatar
31 Jan 2010 19:47
#345752
Jordan, repectfully dis-agree. In a perfect world, Plain bearings never see physical contact.. thus no wear... look at a set of new bearing shells, a wild assed guess is that they're 60-80 thousandths deep, and could never overlap within the tolerances of an undamaged rod or main cap regardless of rpm. spun plain bearings (in my experiance) are the result of either insuficient clearance, or lack of oil. either allowing contact/wear, then partial seizing/galling causing bearing shell to travel. My 2 cents.G
[img][/img] 1977 KZ1000A1
