- Thank you received: 1
Mr. Turbo versus KZone??
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- saxjonz
- KawboyZ
- Thank you received: 76
Just look at it like this...either you put the money in to the bike or not but if you have to think about it then you are ready for much more thinking and at one point you will wonder why you spent so much time and effort thinking. Just go the turbo route and go through all of the growing pains everyone else has had to go through and don't count your pennies and dimes spent. Just forget it man it is a full blown addiction that you can't account for and if your wife asks you, you have no idea how much you spent because it just doesn't matter. It will cost what it costs once you get started.
79 LTD B3
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
- PLUMMEN
just dont think about the cost,life is so much easier without stressing over little things! :woohoo: happy little clouds!i have often found when people are estimating costs on project they should automaticly take the number they came up with and then double it and add 50% that should get you in the ball park
- Jeff.Saunders
what they didnt have done was their biggest issue: a welded crank and a good carb! :laugh: remember a turbo motor is force fed so it doesnt need big cams,big valves ,big carbs,fancy valve train parts...... a solid bottem end with a welded crak and main cap brace is the secret.even with stock pistons and stock head with good valve job and stock cams you can run a few pounds of boost and still have more than a stone stock chassis can deal with on a motor that will idle like stock and run on pump gas with low boost.
My old Z1 (1200cc) with a turbo on it was not very easy to ride with the old Zenith carb provided in the ATP kits. Switching this out to a modern HSR42 carb made a world of different.
I can attest to frame bracing is needed. I can feel the frame flexing under full power at 80+mph. The previous owner did some limited frame bracing, but not good enough for that kind of power.
www.z1enterprises.com
Z1 Ent on Facebook,
- mark1122
- Keep twisting it
Thats what i thought. i have never read anything about the turbo bikes having any extras. Very week thinking on Kawi's part. they knew there race bikes couldnt handle added power, so they give power to the public without anything to suport it. kinda like the widow maker H2 on steroids.lol:woohoo:what they didnt have done was their biggest issue: a welded crank and a good carb! :laugh: remember a turbo motor is force fed so it doesnt need big cams,big valves ,big carbs,fancy valve train parts...... a solid bottem end with a welded crak and main cap brace is the secret.even with stock pistons and stock head with good valve job and stock cams you can run a few pounds of boost and still have more than a stone stock chassis can deal with on a motor that will idle like stock and run on pump gas with low boost.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
