Mr. Turbo versus KZone??
- Heavy- Z
Any knowledge on the subject would be helpful.
Thanks in advance
- PLUMMEN
- Thank you received: 104
- jordan
- Thank you received: 5
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Jeff.Saunders
What is your budget?
How would you use the bike?
Are you going to race it?
Do you want to be paying for race fuel everytime you take the bike out?
The nice thing about a turbo setup is you can adjust the boost - run 6-8 pounds of boost on street fuel, and then take it to the track and run 115 octane and 20+ pounds of boost.
Heat is the enemy of performance engines - you wouldn't want to be running either big-block motor or a turbo setup in very hot areas.
If you want a super fast motor, you need to spend a lot more than is first obvious... $4k for a turbo kit, add $3k more for all the other stuff (pistons, crank weldng, head work, etc)...
$2k of parts from Jay is the tip of the iceberg too...
www.z1enterprises.com
Z1 Ent on Facebook,
- PLUMMEN
- saxjonz
- KawboyZ
- Thank you received: 76
I had to spend quite a bit more in parts than that. You will need to take that head and send it to someone who knows their stuff well who can port it for the kit you are using. You for sure will need a nice oil cooler.
If you still have the original ball bearing steering bearings you are looking for trouble and let's not forget with all that power to the rear you will need a nicely built swing-arm either way you go turbo or NA. The stock one aint gonna cut it especially with those old bearings in there.
Did I mention carburators? Stock carbs on that setup will not work. You will have to buy some new carbs like the beautiful flat-slide 34's that will cost a penny or two. And then pods.
If you go that big you will have the big block set-up which will breath much less when it comes to heating up. My 1075 got extra hot yours will melt your pistons if you ride it on the street stoplight to stoplight.
If I had it to do again most certainly I would try the turbo route like Jeff said you can vary the boost majorly. But if I seriously had it to do all over again I would have restored the bike to immaculate condition doing all of the chassis work first like I am doing now and would have taken the head and the crank and possibly even the gears if they weren't in the best shape and sent them out to have the boys work them over, put all the heavy duty chain and roller parts in replace all the stuff and build the bottom end like a bullet, get some really nice carbs, pipe and baffle along with dyna ignition and put it together after I had done the chassis up really nice and THEN see how you like it.
Hell, my bike in stock form with my setup of dyna, 29 smooth bores, v&H with comp baffle and very finely tuned ran like stink. In fact, I raced one of the guys on here with a big bore kit and we were head and head up. So that says a few things...the head will only flow so much if you don't work it over and put oversized valves and spend a bit of money. You are not going to be able to do that work yourself.
ONLY reason why I took her down was because it had a blown head gasket from the PO that just progressively got worse and the bike still ran strong! While it was apart I thought what the heck let's do the 1075 everyone raves about being the perfect combo for the street and I personally think in retrospect that I would have been happier leaving it stock and just buying a zx-14 for my need for speed and gotten off much cheaper and happier in the long run.
If you like worry free riding and do a lot of riding keep your old girl stock and buy the zx-14. I see new ones for sale advertised at 8k 08. At most 95 otd tax title and plates. I see you spending on an oil cooler, swing arm, parts close or more than half of that plus if you put it together you may make mistakes or if you pay someone to do it you will be more than a new bike.
What have I decided to do? Finish my bike to show finish and do my 79 stock with headwork and crankwork, back-cut gears and stock other than that so I can ride it! Or get the zx-14 use the Z for my weekend fun longer no stopping ride and hit the zx-14 around town and anywhere else she wants to go. Today if I get the price that is stupid cheap because they need to get rid of their old stuff I will for sure consider buying one. Although, I am trying to be strong and sensible. Why would a guy need three bikes if he can only ride one at a time. But a 14 for basement bargain prices who can resist plus you get six months interest free so if you have a wad saved to fix up your bike then you could drop it on the down payment and have the bike finished being paid off before six months hits and you're golden.
Just don't think you can get away with building that bike up and riding it like a normal beautiful z. It ain't ever gonna happen no matter what anyone says and you are going to have to take it down to replace leaky head gaskets or other things that can and will go wrong. If you are that type of person I say GO for it but have a second stock z to tool around on reliably. I don't think you are though or you wouldn't be asking these questions. Just restore your bike chassis first and later make those decisions about building the stink out of the engine. :S Good luck and may the force be with you.
79 LTD B3
- RonKZ650
- Thank you received: 240
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
ok just dont have a nighmare about a repaint and turbo install on the same bike! :S the place wouldnt be the same without ya Ron! :woohoo:I had a bad nightmare last night. I dreamed I bought a turbo kit and was installing it. Woke up from that in a sweat. Not as bad as a repainting nightmare, but second worst. I'm not kidding, other night I dreamed I flipped the goldwing over backwards in a wheeley at 75mph. That was not nearly the nightmare of the paint or turbo saga.:laugh:
- kawsakiman
- Thank you received: 6
amen brother!
either way this is going to cost you.
it's up to personal preference now.
decide which way you want to go and there are more that enough people here to help you along.
and for future reference, when you think you might be close, break out another $1,000
- timebomb33
I THINK MY POWERBAND BROKE
- keith1
i have often found when people are estimating costs on project they should automaticly take the number they came up with and then double it and add 50% that should get you in the ball park
amen brother!
truer words were never spoken.......
