- Thank you received: 18
She's Been Sittin' fer 8 Years!
- Kawickrice
29 Jan 2010 12:59 #345273
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic She's Been Sittin' fer 8 Years!
I would rather ride that than the GS1100 shaft I ride now. Its amazing what some paintin and polishin will do to her
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- chance
- Life long biker/
29 Jan 2010 14:10 #345279
by chance
Replied by chance on topic She's Been Sittin' fer 8 Years!
What does the clutch pull feel like? Is the cable pulling your clutch relese? My cable was froze on my copper..
- kilgore
29 Jan 2010 14:19 #345281
by kilgore
Replied by kilgore on topic She's Been Sittin' fer 8 Years!
Yeah, Chance, "pull" feels good - could see plate moving when I had cover off. Could only get 4 plates (w/their disks) off. I think there are 9(?). Just got some more fuel - gonna fire 'er up and see if the rest will break loose. Will report back. Thanks again everybody!
- kilgore
29 Jan 2010 15:05 #345289
by kilgore
Any thoughts on clutch cancel switch? I disabled it years ago - hafta ground two wires on handlebars to start 'er.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
29 Jan 2010 18:07 #345314
by Skyman
West Linn, OR
Replied by Skyman on topic She's Been Sittin' fer 8 Years!
kilgore wrote:
Remove the tank. There should be a two-wire connector under there somewhere where the wires come down from the left handlebar. You can disconnect that, then with a small length of wire, jump the two wires on the engine-side connector. You can just tape it up and leave it that way if you want. Then you won't have to pull in the clutch (or ground the wires on the handlebar) when you want to start it.
But just make sure you are in neutral!
West Linn, OR
- kilgore
29 Jan 2010 18:25 #345318
by kilgore
Hey, Skyman, my fellow Oregonian,. As you know, it's Beer:30 here in ol' Multnomah County, so I'll check that out tomorrow - thanks! By the way, you asked, I'm up in St John's. Maybe we can go ridin' in a couple weeks?
- Skyman
31 Jan 2010 09:59 - 31 Jan 2010 10:03 #345596
by Skyman
West Linn, OR
Kilgore, I'd love to go riding if we can get some decent weather on a Saturday.
I did get in a ride last Saturday during a brief break in the weather. Went up along the Clackamas river.
West Linn, OR
Last edit: 31 Jan 2010 10:03 by Skyman.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
31 Jan 2010 10:18 #345599
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic She's Been Sittin' fer 8 Years!
With the bike on its side stand, pull off the clutch cover.
Remove the clutch spring bolts.
Remove the spring plate.
Remove the clutch pack (all the discs) as one.
Pry them apart with a small plastic knife.
Clean them individually in a pan with new oil and a soft brush.
Use new gasket/rtv gasket maker. If you must use old gasket, I've had luck with using brake cleaner on both the old gasket and the surfaces, and letting them dry completely before assembly.
90 inch-pounds on bolts.
Installation is reverse of removal.
A very quick and easy process that can be done in about 20 mins with some experience.
Good luck!
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kilgore
31 Jan 2010 10:56 #345611
by kilgore
Thanks everybody. Busted clutch apart. Problem seems to be clutch lockout switch, which I disabled years ago. Have to start her touching both wires to handlebars, but now wires seem to have to be grounded to shift into gear?!?
