She's Been Sittin' fer 8 Years!
- kilgore
28 Jan 2010 16:46 #345128
by kilgore
She's Been Sittin' fer 8 Years! was created by kilgore
Hi everybody - new guy here. '87 KZ1000 P7. After many long battles (and beers), got 'er to fire. Once warm, she idles pretty good for an old gal. All fluids flushed/changed, new batt, carbs removed cleaned,basically all the usual stuff. However, she dies instantly when "clackin'" 'er into gear. Did the clutch release adjustment @ sidecover. What's next? Thanks for any help you can give. This is my first post but have been reading you guys for some time and know this is the place to be!
- Kawickrice
- Thank you received: 18
28 Jan 2010 16:49 #345133
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic She's Been Sittin' fer 8 Years!
Does it try to surge when you clank it in to gear like a clutch adjustment. Or is it like an electrical thing where she just dies from no power?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kilgore
28 Jan 2010 16:55 #345137
by kilgore
Replied by kilgore on topic She's Been Sittin' fer 8 Years!
Ooh, that's a good question. She pretty much dies immediately (no reckocnizable surge). I'm a little afraid to give 'er the juice before I go into gear 'cause she's been sitting so long I don't really trust 'er again yet - don't wanna crash into my truck, lol!
- flht1997
- Thank you received: 2
28 Jan 2010 16:55 #345138
by flht1997
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Replied by flht1997 on topic She's Been Sittin' fer 8 Years!
Sidestand switch? Sounds electrical
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
- keith1
28 Jan 2010 16:57 #345139
by keith1
Replied by keith1 on topic She's Been Sittin' fer 8 Years!
first off...Welcome.....do you have a manual? if your bike is similar to the older kz's, its a multiple step method to clutch adjustment.....you have to close mid adjuster all the way in and bar adj all the way in....do your side cover adjustment(which you did), then take out the slack at the mid-adjuster, then adjust at the lever.....
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
28 Jan 2010 16:59 #345140
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic She's Been Sittin' fer 8 Years!
i would say a sidestand switch. My GSXR 1000 has the same thing, i have looked like an idiot more than a few times when i go to take off and the bike dies.......lol
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- kilgore
28 Jan 2010 17:08 #345146
by kilgore
Thanks you guys. Sidestand switch seems to be disabled. I see two greasy ol' leads (with no wires) coming off the front of what looks like a switch at front of stand. Never messed with that all the time I was riding. One thing, the rear tire used to spin on center stand at idle and doesn't now.
- kilgore
28 Jan 2010 17:21 #345149
by kilgore
She just started in gear!?! "bout rocked 'er off the center stand. Still won't go from nuetral to first.
- anarki650
- Thank you received: 5
28 Jan 2010 17:21 #345150
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic She's Been Sittin' fer 8 Years!
I'd be looking for the wires for the sidestand switch and make sure they are jumped together. Might be someone jumped the wires at some previous time and just twisted them together and they have since come untwisted. Just a thought...
09 Kawasaki ER6n
Omaha NE
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
28 Jan 2010 17:34 - 28 Jan 2010 17:47 #345153
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic She's Been Sittin' fer 8 Years!
If it lurches at all, the clutch plates could be fused... It happened to my 650 when I let it sit just 2 years. Rev it up pull the clutch lever and kick it into gear to knock them free. I needed to do it a few times to get them to let go.
1977 kz650 c1
Last edit: 28 Jan 2010 17:47 by hardr0ck68.
- kilgore
28 Jan 2010 17:43 #345155
by kilgore
Now yer talkin'! Thanks hardrock - probably just what the old gal needs! I been at this for a while today. Time for a shower. I'll get back to it tomorrow. Thanks to everybody for your help!!!
- Thank you received: 2829
28 Jan 2010 18:22 #345160
by 650ed
Replied by 650ed on topic She's Been Sittin' fer 8 Years!
If the clutch plates seem glued together you should be able to free them like this: If you can, start her in 1st gear on the center stand; then give her some gas so she's spinning the rear wheel at a fair clip; while feeding her gas pull in the clutch and apply the rear brake. This will result in the engine applying force to the clutch hub while the brakes are applying opposite force to the clutch housing (or vice versa). With the clutch pulled in the 2 opposing forces should break the bond between the clutch friction plates and steel plates. You may want to have a second person hold the front of the bike solidly on the ground while you're doing this; you wouldn't want to lean back too far and have the rear wheel touch down while spinning or you might clobber the truck. Ed
