- Thank you received: 6
Installing cylinder studs
- kawsakiman
when are you going to bring your ass back to ny?
of course you better first use compressed air to clean the bolt holes.
then run a TAP down them.
blow them out again, tap again etc.
wtf man?
you want a 14k motor but keep asking some dumb ass questions.
you all ready know most of the answers to these questions so why do you keep asking?
i have already offered to help you for free many times.
you won't listen to advice given and sometimes seem like you would pefer to argue then accept any advice or tips from fellow members.
wtf man?
i'm not trying to start a flame war or offend you but for crist's sake, just listen to someone who has been there and done that.
tap, blow,tap,blow clean, tap blow etc...........
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
Look over this thread, I have advice to use a tap, to use a thread chase, and to do nothing at all. I was hoping I would get clear confirmation of what I already think I know.
I learned the hard way it is easier to remove metal than to put it back, so in this case I am gonna try and not remove any more. So why wouldn't I be looking for a proper sized thread chase?
I am not doubting you know your crap, just asking you to explain it to me.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- APE Jay
- Banned
- Thank you received: 58
Then they are on the phone to us stating their new studs are too short.
If you must put a tap in there, make sure you don't do this, or you may wind up having to do the old ball bearing trick.
Here is the installation tool;
racetoolz.com/
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- APE Jay
- Banned
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- hardr0ck68
Just running in the set screw. Whats this about a ball? Is there one in that tool?
According to description from the web page Jay linked out to there is no ball bearing.
Here is the description:
STUD INSTALLATION TOOL
This tool makes it easy to install cylinder and main bearing studs. No more double-nutting. The set screw contacts the top of the stud. Easy to put on and remove. $15.95 ea.
Not to pick on you Jay, you just made me wonder as well!
1977 kz650 c1
- kawsakiman
A word of caution. We don't recommend running a tap in the cases. The reason is because the threads in the case don't go all the way to the bottom. When people screws taps in there, they don't know when to stop, and wind up tapping the hole deeper.
ht/
very good advice from a pro. and well heeded. it's cool you take time out to offer advice to people who buy your products.
but if you can't tell from the feel when you are cutting new threads and no longer just cleaning existing threads, maybe you should farm out that part of your rebuild to someone with a little more experiance.
just my .02
- mark1122
- Keep twisting it
- Thank you received: 109
as for finding the right stud height. install them add the block, gaskets and head. do not torque. check the stud heights.
If any are too short, u can either Red Locktite them in at the right height or put something under them. I put some lead fishing weights under mine and squashed them in as i torqued the studs. just keep adding lead until reach the desired height.
I just use the double nut method.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
