- Thank you received: 3
Installing cylinder studs
- hardr0ck68
- Who put the what in the where?
So I am now wondering what is the proper way to install them?
Just toss a nut on the top threads and tighten unto the torque spec is reached?
How do you insure all studs are level?
Should I run a tap down the case threads?
Should I use sealent or never seaze on the threads?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Old Man Rock
- Thank you received: 225
HF Tools also sells a stud remover but as TB mentioned, 2 nuts method worked just fine in my build...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- hardr0ck68
Before removing any of the studs... Measure existing heigths off the deck and record accurately for when installing the new studs...
I picked up a stud puller from e-bay. I got a snap on one, had a mechanic friend kill it (not only can he fix stuff he can break it to if need be!) then the snap on guy gave me a new one.
Not the most honest thing but I got a $90.00 tool for $15 shipped
1977 kz650 c1
- hardr0ck68
1977 kz650 c1
- MFolks
- Thank you received: 540
If you did use a tap with the point you might pierce the case where an oil gallery is and have endless problems.
Vacuum out any hole you "chase" with the new tap. A blast of air might work, but I like to vacuum tapped holes myself.
- keith1
snap on is snap on.....they price their stuff so high they can eat a couple.....
- hardr0ck68
On top of that my buddy looked at my stud puller and said "that's the cheap one" he explained to me he now has a set of 20 of little socket like things each meant for a specific size stud! I can only imagine how much that set cost him!
hurm;
So now I have one vote bottoming tap, one vote thread chase...
1977 kz650 c1
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
I know that the snap on man OWNS my buddies kidneys so I don't feel any remorse. I mean yes he is a mechanic so he uses the tools every day, but $1,000 for a torque wrench?!?!? $500 for a socket set?!?! It takes a lot of tire rotations to pay for that stuff!
hurm;
just yank the old ones and squirt a little wd down there and blow em out...put a light down there and verify cleanliness and follow instructions on back of packaging..
double nut them in and use torque wrench to spec....done!
- hardr0ck68
1977 kz650 c1
- kawsakiman
- Thank you received: 6
snap on is snap on.....they price their stuff so high they can eat a couple.....[/quote]
you know what they sat about snap on.
you can buy better but you will never pay more.
just ask bluemeanie
