29mm Shims
- KLD
Looks like im going to need these;
4x 2.55mm
2x 2.50mm
I have a these;
3x 2.60mm
1x 2.75mm
1x 2.70mm
1x 2.80mm
If anyone would swap me, That would be awesome. Let me know soon
- Old Man Rock
- Thank you received: 225
Some tips I got from Plum and Larry as well...
Exhaust side gets really heated up no doubt. With this in mind, go with these specs instead for the exhaust side normally decreases this distance during the break in period and heat...
Spec is .05 to .1mm for both intake and exhaust....
Exhaust Shims: .1 to .15mm
Intake shims: .05 to .1mm
As always, followed their reasoning and experience, set accordingly and in my 500 mile re-checks, found the exhaust shim spacing had indeed decreased... Guess where they now reside...YUP, .05 to .1mm for both intake & exhaust!
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- KLD
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- KLD
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
- otakar
I have a lot of 2.55, 2.60, 2.65, 2.80 to trade.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- keith1
the sizes I nead are 2.10, 2.15, 2.20, 2.35, 2.75, 2.90, 3.00, 3.05, 3.15 I will take any combination of 4 for the 4 2.55s
might be a confusing 3-way trade....otto, i have 2 2-90
and 2 3-00....
what do we want to do?....2-60, 2-65 works for me
- KLD
3x 2.60mm
1x 2.75mm
1x 2.70mm
1x 2.80mm
Untill I get your shims. I got no extra shims to put in as temporarys.
But, basically I'll send keith1 all of my shims except the 1x2.75mm which I will send to okotar. Keith1 will send me his 2x2.50mm shims. Keith1 will send his 2x 2.90mm and 2x 3.00mm to okotar. Okotar will send his 4x 2.55mm shims to KLD(me). Okotar will send whatever keith1 wants for his 2x 2.90mm and 2x3.00mm.
Does this sound right? If so, ill send a message to both of you with my address and you can then send me yours.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
[Sorry.]
