- Thank you received: 2
29mm Shims
- keith1
Old Man Rock wrote:
Triumph shims are 29mm as well...
I pick mine up local T shop, $6 each....
Wish I could find a place in nebraska that had shims, lucky guy. I'm dreading ordering shims from z1 enterprises, then reordering more shims when I figure out what i need.
have plummen throw a concussion grenade in his bunker and it will rain shims......:woohoo:
- PLUMMEN
- Thank you received: 104
nebraska,where at in nebraska? :blink:ive got another 900 parts bike i drug home in back of van,let me see if motor turns over tomorrowOld Man Rock wrote:
- KLD
- PLUMMEN
- PLUMMEN
- PLUMMEN
- PLUMMEN
- KLD
- PLUMMEN
- BSKZ650
- Thank you received: 14
im getting ready to head out the door to start another very long day,24 hours worth of work to stuff into the next 12! :S hopefully my help will appreciate me saving the world so they get to sleep a few more hours! :woohoo:
Your starting to sound like Underdog,,,lol
77 ltd1000, current rider
76 kz900, just waiting
- otakar
Welp. The sizes are, starting from exhaust working left to right and then starting again on left side of intake.
(1)2.60mm
(2)2.70mm
(3)2.80mm
(4)2.75mm
(5)2.60mm
(6)2.60mm
(7)2.60mm
(8)2.60mm
I might be able to fix 2,3,4 with the shims I have currently. I don't know if I can spin the shims. I'm currently putting the cams back on. Ill let you know in a bit
It looks to me that you will require a bunch of 250/255 shims. I would get one 240 shim and use that to check all the measurements. It looks like that you will have the shims to set maybe 3 of your valves and have to replace the rest.
I don't think that I would want to use the Taurus shims. They have a hole in them that will allow air to get between the shim and the bucket more easily than the shims we use. This can cause the shims to be spit out at the RPM we run our engines at. I use the standard Yamaha motorcycle shims because of the lower price.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- KLD
