29mm Shims
- KLD
29mm Shims
27 Jan 2010 09:53 - 06 Feb 2010 10:27
I'm currently rebuilding a 73 z1 and when I measured the clearance with a feeler gauge I couldn't get my smallest size gauge under there (.0015"). No place around here sells shims and I don't have a clue on what size I'm going to need (only that I need smaller then 2.60mm), I really don't have 200$ to play a guessing game buying shims. Anyone have any suggestions?
Edit,
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=346843
For shim swapping
Edit,
For shim swapping
Last edit: 06 Feb 2010 10:27 by KLD.
- Kawickrice
Re: 29MM Shims
27 Jan 2010 10:00
You will have to get a hold of some smaller shims. Put the smallest one in then measure and make your calculations from there
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Mcdroid
- Gone Kwackers
Re: 29MM Shims
27 Jan 2010 10:32
KLD wrote:
I think the issue is that each valve shim adjustment might be unique...so you are looking at a maximum of 8 different shims...probably less. You either need to find a KZR member that has a nice selection of shims and is willing to swap them one-for-one, or find a local bike shop that deals with old Kawasakis and swap them one-for-one.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Re: 29MM Shims
27 Jan 2010 15:39 - 27 Jan 2010 15:47
With the cam lobe pointing away from the bucket, will the shim turn underneath the cam?
If so, there's at least some minimal clearance, albeit woefully insufficient clearance, and the next thinner size shim may afford correct clearance. If not, may require two sizes thinner.
Could remove all existing shims, and carefully record the size and location of each existing shim. Likely the existing shims will be various different sizes.
Take the thinnest existing shim and put it where the thickest shim was removed from to see if there's then sufficient clearance to calculate the correct size shim needed for that particular valve.
Repeat this process for each bucket, testing clearance with the thinnest existing shim.
For the bucket with the thinnest existing shim and insufficient clearance, a new thinner shim will be needed, perhaps two sizes smaller.
Good Luck!
Good Luck!
Last edit: 27 Jan 2010 15:47 by Patton.
Re: 29MM Shims
27 Jan 2010 15:45
If any of the old original "dimpled" shims are still there, they should be discarded.
As I recall (but could be wrong), Kawasaki redesigned the shims early on because the dimpled version had a tendency to crack.
Good Luck!
Good Luck!
- nebiker51
Re: 29MM Shims
27 Jan 2010 15:57
Yamaha used the same shims in some of their bikes. Back in the seventies the Yamaha shim was about half the price of the Kawasaki shims.:woohoo:
77 KZ1000 LTD - original owner
79 650xs - street tracker project
91 HD FXLR Custom - original owner
- Old Man Rock
Re: 29MM Shims
27 Jan 2010 16:29
Triumph shims are 29mm as well...
I pick mine up local T shop, $6 each....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KLD
Re: 29MM Shims
27 Jan 2010 16:34
Welp. The sizes are, starting from exhaust working left to right and then starting again on left side of intake.
(1)2.60mm
(2)2.70mm
(3)2.80mm
(4)2.75mm
(5)2.60mm
(6)2.60mm
(7)2.60mm
(8)2.60mm
I might be able to fix 2,3,4 with the shims I have currently. I don't know if I can spin the shims. I'm currently putting the cams back on. Ill let you know in a bit
(1)2.60mm
(2)2.70mm
(3)2.80mm
(4)2.75mm
(5)2.60mm
(6)2.60mm
(7)2.60mm
(8)2.60mm
- KLD
Re: 29MM Shims
27 Jan 2010 16:35
Old Man Rock wrote:
Wish I could find a place in nebraska that had shims, lucky guy. I'm dreading ordering shims from z1 enterprises, then reordering more shims when I figure out what i need.
- Jeff.Saunders
Re: 29MM Shims
27 Jan 2010 16:39 - 27 Jan 2010 16:39
Ford Taurus SHO shims are 29mm too. Yamaha made that engine for Ford.
While they don't span the full range of thicknesses needed for KZ's, the Ford shims are available in 1/2 sizes... very nice for refining the clearances for optimum settings. I'm not sure of all the years - but certainly the early 90's thru mid to late 90's.
Last edit: 27 Jan 2010 16:39 by Jeff.Saunders.
- keith1
Re: 29MM Shims
27 Jan 2010 17:16
Jeff.Saunders wrote:
interesting...ya learn something new everydayB) ..i knew yamaha made them, but didnt know they had shims....i know they are high maintenance cars in SHO trim...go like stink,but high maintenance....
- keith1
Re: 29MM Shims
27 Jan 2010 17:26
KLD wrote:
got any idea what you might need? i have a full shim set i bought from z-1 and used some of them...i have to look, but i think i have a few of the smaller thickness....let me know if you are interested....i m willing to trade....
Old Man Rock wrote:Triumph shims are 29mm as well...
