1980 Z-1R... Which motor?
- muskwa
23 Jan 2010 13:17 #344101
by muskwa
1980 Z-1R... Which motor? was created by muskwa
I have a 1980 Z1R with the factory motor. Is it a MkII? It has a roller cam chain, not hyvo, but i didn't count the teeth on it.
Thanks In Advance,
Gavin
Thanks In Advance,
Gavin
- PLUMMEN
- Thank you received: 104
23 Jan 2010 13:56 #344106
by PLUMMEN
Replied by PLUMMEN on topic 1980 Z-1R... Which motor?
if its origional its a mkII,should be 32 teeth on cam sprockets
- muskwa
23 Jan 2010 18:21 #344166
by muskwa
Replied by muskwa on topic 1980 Z-1R... Which motor?
Thanks Plummen.
Is it still 28 pins between cam chain marks on the mark II?
- PLUMMEN
23 Jan 2010 18:22 #344167
by PLUMMEN
yep,just has bigger sprockets because of bigger center crank pin has 16 teeth instead of 15 like small crank.
- muskwa
24 Jan 2010 09:11 #344293
by muskwa
Cool, thanks!
- Thank you received: 797
25 Jan 2010 09:42 - 25 Jan 2010 09:45 #344488
by 531blackbanshee
Replied by 531blackbanshee on topic 1980 Z-1R... Which motor?
question asked,question answered.
now it is picture time,we need to see some pics of this z1r you are working on.we run on pics around here,they are the only thing that keep us going :laugh: .
here is mine,
here is mine,
Last edit: 25 Jan 2010 09:45 by 531blackbanshee.
- muskwa
25 Jan 2010 20:02 #344582
by muskwa
It's a bike i've had on the back burner for far too long... I'll try to post some pics tomorrow. I'll tell the story when I post the pics...
- muskwa
30 Jan 2010 10:49 #345384
by muskwa
The Story:
It's the summer of 1987, I'm 18 and have my first good money job. My big brother and his friends are all into hotrod japanese fours. I take my paycheck and dad's truck to Alberta Cycle in Edmonton and find a clean Z-1R with some street stroker shocks and a nice looking Wolf 4 into1 header for $1500. Have a blast riding all summer...
About October, I'm thinking I need MORE POWER for the next spring so I can be cool like big bro and his cronies. I check out RK Racing, a Kaw-based speed shop in Edmonton, to talk about bigbore,cams,etc. Randy, the owner, points out an ad with a Russ Collins turbo kit a local guy has for sale. I think I paid $700...
That winter, I split the cases, get the crank welded, get a valve job and better springs installed, and re-assemble. The bike runs well enough to do some serious burnouts in my dad's garage, and I can't wait to road-test it in the spring.
Spring comes, the bike makes killer power until the gravity-fed float bowl drains, then falls flat. Work gets crazy busy, I end up working a couple of months of 12 hour shifts, so no time to work on the bike. About this time, my childhood pal Mel is getting the Z-1 bug too. He wants to borrow my bike to go to a rally down south. Like a big dummy, I tell him that if he installs a fuel pump and regulator, then he can borrow the bike, cause i'm working all the time anyway. He installs the parts, and tries it out in my dad's gravel driveway. The rear tire digs a trench the length of the driveway and about 4" deep, filling the garage with gravel. Mel thinks this is fantastic, and wonders how it will work on the pavement... He takes the bike on the street in front of dad's house, wicks it WFO and dumps the clutch. After spinning the tire for about 30', it hooks up and does a violent wheelie, smashing the windshield against Mel's chest and crashing onto the neighbor's lawn. Broken fairing, windshield, seat cover torn, bars bent, front brake lever perch busted, turn signals busted. Mel has a new respect for boost, but no money... He repairs the broken fairing and paints it, and the bike is parked...
November 2009 or so, I'm surfing the net, and come across KZRider forums. I find out that all of the Z1R parts that I need are much easier to find than they were 20+ years ago. So the rebuild begins...
The Pics...
The Pics...
- muskwa
30 Jan 2010 10:51 #345387
by muskwa
Having trouble with the pics...
- Mark Wing
- Thank you received: 22
30 Jan 2010 11:22 - 30 Jan 2010 11:27 #345398
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 1980 Z-1R... Which motor?
Cool story. Try hosting your pix at
www.photobucket.com
it's free and then just copy and paste the IMG line to your post.
Mark
Mark
Yorba Linda Cal.
Last edit: 30 Jan 2010 11:27 by Mark Wing.
- muskwa
30 Jan 2010 11:30 #345401
by muskwa
- mark1122
- Keep twisting it
- Thank you received: 109
30 Jan 2010 14:04 #345415
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic 1980 Z-1R... Which motor?
:woohoo: :woohoo:
you will be so glad u kept that old girl.
Good luck with the restore.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
