The pistons that came out of my bike
01 Jan 2010 18:30 - 01 Jan 2010 19:18 #341531 by Buda
They look pretty rough to me but the bike ran good. What do you guys think. 82LTD1000 20000 miles, the guy I bought it from ran it with pods without rejeting for a couple years. It dosnt really matter because Im ordering new pistons any way.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 01 Jan 2010 19:18 by Buda.
01 Jan 2010 19:30 #341532 by PLUMMEN
Replied by PLUMMEN on topic The pistons that came out of my bike
did you check the bore before ordering pistons? B)
01 Jan 2010 20:00 - 01 Jan 2010 20:07 #341536 by Buda
Replied by Buda on topic The pistons that came out of my bike
Gona use a different set of cylinders. 1100 bored a little and higher comp pistons. As far as the old pistons go, do they look as bad as I think they do? The bike ran good :huh:
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 01 Jan 2010 20:07 by Buda.
02 Jan 2010 02:45 #341550 by Mcdroid
Replied by Mcdroid on topic The pistons that came out of my bike
I've got a 1977 1000 apart right now and the piston skirts are similar to yours...rephrased, the skirts have scrapes and telltales also...how did your bores look?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
02 Jan 2010 06:38 #341560 by Buda
They look about like the pistons with #1 being the worst.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • ready2ryde1985
  • got to love these kzs
02 Jan 2010 10:08 #341578 by ready2ryde1985
Replied by ready2ryde1985 on topic The pistons that came out of my bike
Wow my 700 is showing 19 on the clock ! Think my pistions are that bad? did the last owner not change the oil? How can you prevent that from happening after you put in the new pistions?
84 kz 700 a1
82 kz550 ltd
02 Jan 2010 12:27 - 02 Jan 2010 12:32 #341596 by otakar
Replied by otakar on topic The pistons that came out of my bike
Those pistons are actually in very good shape. Those pistons could be re-used without any problem. All you have to do is measure them and compare them to spec. You will find out they are almost like new. If pistons are warn out they look nothing like that. I measured my pistons from my 76 900 with 55,000 miles on them and they were still well with in spec. 20,000 miles- the bike is just starting to brake in. My 81 CSR had 28,000 on them and they measured same as new.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 02 Jan 2010 12:32 by otakar.
02 Jan 2010 13:52 #341605 by kawsakiman
Replied by kawsakiman on topic The pistons that came out of my bike
they don't look too bad to me either.
really abused pistons have tell tale black mark scrapes on the thrust side from winding the wee out of the motor.
02 Jan 2010 14:31 - 02 Jan 2010 14:34 #341608 by otakar
I bet that if you pulled the pistons out of a bike that had 5000 miles on it they would look the same as these do. This is one advantage of having long piston skirts. They just don't ware out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Jan 2010 14:34 by otakar.
02 Jan 2010 14:55 #341610 by Buda
Cool like I said it ran good. I was just surprised by
the scratches on the skirts.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • trianglelaguna
02 Jan 2010 15:17 #341613 by trianglelaguna
Replied by trianglelaguna on topic The pistons that came out of my bike
i keyed in on the words...it ran good..... and was afaraid to say that they were probably the same as most of the other members pistons....
glad someone else said it....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
02 Jan 2010 15:31 #341617 by PLUMMEN
looks to me like somebody took a scuff pad to them at some point in their career,horizontal scratches around piston skirts? :blink: look at the color of the rings ,then look at the piston skirts am i the only one seeing this? :laugh: measure the pistons just for laughs and see how close they are to spec,at minimum im gonna say oil changes were few and far between B)
