- Thank you received: 1
750-4 custom air cleaner?
- polkat
Does anyone know where I can find plans for making this, or at lease a shop that sells them (rather make one)? Thanks!
- will61310
- Thank you received: 6
...1980 LTD 1000...
- Thank you received: 2236
+1 on weight concern. Even with pods, the lack of support that the box provided makes for a much shorter lifespan for the intake manifolds.
- kaw-62046
- JMKZHI
- Thank you received: 48
- polkat
kaw-62046, that box is what I'm talking about.
KMKZHI, cool! Do you remember what website you found that on?
- JMKZHI
- kaw-62046
- Locozuna
Hard to believe a smallish aluminum box would be all that heavy. The manifold rubbers hold the carbs pretty tight, and it could probably be braced if necessary.
It's not just the box it's the carbs themselves and the box. A std the airbox is braced when assembled correctly and the carbs are braced by the engine and the box. Without bracing on both ends of the carbs they want to flop. Now add an unbraced box and you have compounded the effect. I'd brace it. Not real interested in replacing 30 year old manifold rubbers if I don't have to. They are there as a seal and not as support. Gluck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- fastestz1
- Thank you received: 3
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Way overkill, but hardly noticible.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
