750-4 custom air cleaner?
- polkat
20 Dec 2009 16:43 - 20 Dec 2009 16:45
Often in pics on the web I have seen an air cleaner that is a single, long chrome box that attaches to all 4 carbs (and eliminates the black plastic air box). I don't know what they are called, but I like them. I have not seen them in stores, but recently I talked to a guy at a bike show, who told me that he made his own, and that making them was quite common.
Does anyone know where I can find plans for making this, or at lease a shop that sells them (rather make one)? Thanks!
Last edit: 20 Dec 2009 16:45 by polkat.
- will61310
Re: 750-4 custom air cleaner?
20 Dec 2009 17:11
Ive seen them on Ebay every now and then. I would be concerned about all that weight hanging on the back of the carbs, they've just Got to be heavier than a set of pods..
...1980 LTD 1000...
20 Dec 2009 17:15 - 20 Dec 2009 17:19
I think I recently saw one for sale at dragbike.com
+1 on weight concern. Even with pods, the lack of support that the box provided makes for a much shorter lifespan for the intake manifolds.
Last edit: 20 Dec 2009 17:19 by TexasKZ.
- kaw-62046
20 Dec 2009 17:15Please Log in or Create an account to join the conversation.
- JMKZHI
20 Dec 2009 17:32Please Log in or Create an account to join the conversation.
- polkat
20 Dec 2009 22:19
Hard to believe a smallish aluminum box would be all that heavy. The manifold rubbers hold the carbs pretty tight, and it could probably be braced if necessary.
kaw-62046, that box is what I'm talking about.
KMKZHI, cool! Do you remember what website you found that on?
- JMKZHI
21 Dec 2009 08:08
I'm not sure where I found that photo, but most likely it was here, KawasakiMotorcycle.org or KZ650.Info.
- kaw-62046
21 Dec 2009 08:47Please Log in or Create an account to join the conversation.
- Locozuna
21 Dec 2009 10:20
polkat wrote:
It's not just the box it's the carbs themselves and the box. A std the airbox is braced when assembled correctly and the carbs are braced by the engine and the box. Without bracing on both ends of the carbs they want to flop. Now add an unbraced box and you have compounded the effect. I'd brace it. Not real interested in replacing 30 year old manifold rubbers if I don't have to. They are there as a seal and not as support. Gluck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- fastestz1
21 Dec 2009 10:48
they are called "breadbox" henry abe did make them,i have seen guys i ride with run these for years with no trouble due to weight,surprisingly they are extremely lightweight.
- TeK9iNe
- What did you do!?!
21 Dec 2009 11:35
Carbs are easy to tie-up/support. I've used a small length of pipe strapping for a concerned client. Just attached it to the carb rail, then around the center frame above.
Way overkill, but hardly noticible.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Locozuna
21 Dec 2009 15:11
I would not just support them but brace them. So they cannot move up as well as down. But again its just my opinion. I'm sure there are reputable reports of ones not braced that have run for years with no apparent trouble. I'm not willing to chance it as I had a CB360 that I could not tighten the clamps enough to keep the carbs plugged in. It was a wreck that I got from curbside trash and it had not been babied but it was a PITA to keep those carbs in place until we braced them. Now I stay with or install stock airboxes so no more issues anyway. Your results may vary. Gluck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
