- Thank you received: 225
clutch wont engage
- Old Man Rock
As already mentioned.. #1 is FACTORY SERVICE Manual is a must... Study it as preparing for a university final exam...
As for the clutch adjustment... Something I learned off Plummen worked well on my 900.... Keep in mind I installed new friction & steel plates and clutch springs due to components being out of spec or warped.
Unknown what conditions your clutch components are in....
At first, in following the manual, I found it where wouldn't engage until the clutch lever was 3/4 out leaving no adjustment play at the clutch lever cable adjuster... That seemed a little weak for my taste...
Follow the manual instructions up to the point of screwing in until hard...
Here's the change, screw in until you just barely feel it contact the clutch push rod. Then back her out a tad (1/8-1/4 turn) then lock her down & adjust your mid cable adjusters then the clutch lever adjustments.
Now my engagement it in the middle of the clutch lever release where I like it...
Give it a try, may work better for you as well....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- hammerguy09
- keith1
ok so i have come to relalize that the brake fluid also doubles as "clutch fluid" I checked brake fluid and it is bone dry...could this be why i am having the clutch problems...?? Remember..I am a noob so please by nice!
whoever told you that is yanking your chain....no brake fluid results in no brakes....
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- keith1
has somebody done a hydralic clutch conversion on this bike. do you also have a master cylinder on the left side of the bike or is the clutch still cable operated.
hydraulic clutch was the first thing i thought of, but he said he just installed a new cable....
- kano
- Not Another Bloody Limey!
he said in his first post.
hammerguy09 wrote:
hello, I just put a new clutch cable on it and now the clutch wont engage.
- timebomb33
- Thank you received: 2829
- hammerguy09
- timebomb33
- hammerguy09
- MFolks
- Thank you received: 540
It might need cleaning and re-lubrication, the mechanism will need adjustment after re-assembly after reinstalling it on the engine case.
