1981 KZ1000 CSR valve adjustment problem
- saltydog
Thanks,
Robert
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- TeK9iNe
- What did you do!?!
- Thank you received: 28
It's not really a big deal though, when done properly it takes no time at all.
You will need an inch-pounds torque wrench.
Loosen them incrementally in small amounts at a time. Its not necessary to completely remove the caps or the screws, just get everything loose enough to tilt the cams from one side to another to remove the shims.
Once done, put a generous bead of thread locker on the screw threads, then tighten them down incrementally till the are just snug by hand. Then torque them to 85 inch-pounds, then torque them to 95 inch-pounds, and you're done!
Cheers, good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- saltydog
I've had this problem, and in some cases it is necessary to loosen off the cam caps.
That seems to be reasonably simple. Now, next question: If you can't get the feeler guage in at all using a .05 mm guage, is it safe to assume that is sero clearance and you need to subtract the amount of clearance you need from the size of the shim that is in there in order to get the proper shim? What amount of clearance do I need to shoot for?
Ok, that's two questions. Hope I'm not wearing you guys out.
- Thank you received: 2098
After removing the too thick shim and determining its size, could try replacing it with a .05mm thinner shim, and re-check the clearance.
If the existing won't turn at all, it's zero or less clearance. After removing the way too thick shim and determining its size, could try replacing it with a .10mm thinner shim, and re-check the clearance.
Good Luck!
- TeK9iNe
With cam lobe pointed away from bucket, will the existing shim turn? If so, there's at least some minimal clearance. But less than the .05mm feeler gauge. So somewhere between zero and .05mm.
Good Luck!
Perfect!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- zoro
- Thank you received: 1
GHOSTRIDER,1980,KZ1000ST
