- Thank you received: 12
1075 kit on my 74 Z1 900
- oldkaws4ever
- Have no regrets...... You only live once.
08 Dec 2009 00:05 #338027
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1075 kit on my 74 Z1 900 was created by oldkaws4ever
So, i have all the major goodies to start my motor build. I scored a set of very low mile almost brand new wiesco 1075 pistons last lear, i just scored a freshley bored out kz 1000 cylinders bored to 1075. What should i do to my crank?. I wouldnt feel very safe throwing the 1075 kit on the 40,000 mile z1 bottom end. Im going to have it tested to see if it's straight, then have it balanced, then welded. My buddy is one hell of a welder, so im going to have him brace my frame for me. I have the kz 1000 head on there now, if funds are there i will send it to Larry Kavanaugh. Any other idea's or suggestions would be great. Thank you.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- larrycavan
- Visitor
08 Dec 2009 02:45 - 08 Dec 2009 02:51 #338031
by larrycavan
Replied by larrycavan on topic 1075 kit on my 74 Z1 900
The block should be bored to the piston that is designated to run it. Measure the piston to cylinder clearances and check the bores to see of they're straight.
Last edit: 08 Dec 2009 02:51 by larrycavan.
- otakar
08 Dec 2009 04:31 #338037
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic 1075 kit on my 74 Z1 900
1075 is not a large motor for that crank. I am running a very well built 1150 on a stock pressed crank. Make sure that the cylinders fit your cases. You may or may not have to have them bored. Check your ring gaps from your new pistons in the new cylinder block.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
