- Thank you received: 20
1st valve adjustment on this '78 kz1000
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
06 Dec 2009 22:32 #337880
by newOld_kz1000
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
1st valve adjustment on this '78 kz1000 was created by newOld_kz1000
I'm getting ready to replace valve shims on my 1978 kz1000 A2 (standard) model, and I am about 100% sure this will be the first time for this bike as I'm the 2nd owner and the original owner was elderly, a bit crazy and lazy when it came to maintenance. Which may be well within acceptable operating parameters for an elderly biker. (I'm not sure as I'm an 'old' biker, not elderly though -- yet.)
I think I know the answer to this -- but will ask anyway -- what stock, standard shim sizes am I going to find when I remove the original factory-installed shims?
I'm replacing about half the shims due to insufficient clearance between the cam lobe and the shim (needs to be .05mm to .10mm, and 4 of mine are a bit less than .05mm).
So I *know* I'm going to install, most likely, the next smaller size shim on these 4 out-of-spec shims.
Just wondering -- what stock, standard shim sizes am I going to find when I remove the original factory-installed shims?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
06 Dec 2009 23:59 #337882
by Skyman
West Linn, OR
Replied by Skyman on topic 1st valve adjustment on this '78 kz1000
Why not just open her up and check? It's not a big job to remove a shim and measure it--if you have the right tools. You'll need the special shim remover tool and a micrometer to measure the thickness.
As far as I know, there is no way to predict what size of shims were used from the factory. But I THINK they shoot for somewhere in the mid range (240-270). But I'm not positive on that.
West Linn, OR
- donthekawguy
- Thank you received: 8
07 Dec 2009 00:21 #337883
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic 1st valve adjustment on this '78 kz1000
They used whatever shim they needed from the factory. There isn't a standard size they used for all of the valves. the only way to know is to pull the shim and take a look.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- roy-b-boy-b
- Thank you received: 103
07 Dec 2009 02:26 #337889
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1st valve adjustment on this '78 kz1000
I have seen a lot of 270 sized shims. I mean a lot. Roy
- PLUMMEN
- Thank you received: 104
07 Dec 2009 05:10 #337899
by PLUMMEN
Replied by PLUMMEN on topic 1st valve adjustment on this '78 kz1000
hopefully your origional ones are on thicker end of scale so you have plenty of adjustment left in there,remember exhuast side needs more clearance than intakes since they run hotter
- newOld_kz1000
07 Dec 2009 22:29 #338018
by newOld_kz1000
Replied by newOld_kz1000 on topic 1st valve adjustment on this '78 kz1000
PLUMMEN wrote:
I measured and found the following today -- - I used the .038mm, .051mm, .0635mm and .076mm feeler gauge leaves to check:
INTAKE
#1: .038mm/.051mm/.0635mm fit, .076mm DOES NOT FIT
#2: .038mm/.051mm/.0635mm fit, .076mm DOES NOT FIT
#3: ALL FIT (.038mm to .076mm)
#4: .038mm fits, .051mm *barely* fits, .0635mm and 076mm DO NOT FIT
EXHAUST:
#1: ALL FIT (.038mm to .076mm)
#2: .038mm/.051mm fit, .0635mm and 076mm DO NOT FIT
#3: .038mm/.051mm/.0635mm fits, .076mm DOES NOT FIT
#4: ALL FIT (.038mm to .076mm)
With the data above I only removed the #4 intake shim and the #2 exhaust shim.
The #4 intake shim read '230' and the #2 exhaust shim read '275' -- so I'm going to a 225 and a 270 as per the FSM to increase the clearance on those 2 valves -- is that logical?
While these 2 valve were *technically* in range since both cleared .05mm, that's the very minimum clearance -- they did not clear the next .0635mm feeler leaf -- and I don't want to have to open it up again in 3 months just to have to do the shim swap above (in Silicon Valley we can ride all winter), I *know* I'm going to need to increase the clearance on these 2 valves PDQ anyways, may as well do it now while she's open.
INTAKE
EXHAUST:
- bountyhunter
- Thank you received: 337
07 Dec 2009 22:34 #338019
by bountyhunter
Replied by bountyhunter on topic 1st valve adjustment on this '78 kz1000
I agree. When the clearance is barely wide enough to be in spec, I throw in the next thinner shim as well to go to the higher range limit on gap. Being a thou too wide won't hurt anything, but insufficient clearance can destroy the valve seats.
