Camchain Tensioner Question......
- Martynbiker
- 1993 KZ1000P
04 Dec 2009 16:14 #337529
by Martynbiker
If you cant fix it with a Hammer....... it's gotta be an Electrical problem...
Camchain Tensioner Question...... was created by Martynbiker
Hi Guys, i am a fairly well experienced wrenchmonkey but I need some guidance here.
Is it possible to remove the automatic camchain tensioner on a KZ1000P ( 1993 model) WITHOUT removing the Carbs?
Anyone know?
Thanks
Martyn
Anyone know?
Thanks
Martyn
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 Dec 2009 17:31 #337542
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Camchain Tensioner Question......
If you can access the bolts to extract the tentioner without removing the carbs, then yes, removing the tentioner with the carbs still installed is just fine.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Martynbiker
- 1993 KZ1000P
05 Dec 2009 12:20 #337625
by Martynbiker
Replied by Martynbiker on topic Camchain Tensioner Question......
TeK9iNe wrote:
OK, I will rephrase the question...:laugh:
Has anybody managed to remove tensioner without removing Carbs, and if so, HOW??
Thanks
Good luck.
Thanks
- polkat
- Thank you received: 1
06 Dec 2009 12:07 #337789
by polkat
Replied by polkat on topic Camchain Tensioner Question......
It's done all the time. Look at the tensioner and you'll see two bolts at the top and bottom. Take them out and the tensioner will fall out. Yes, it can be a struggle to get a socket in there, but that's how it's done.
- Martynbiker
- 1993 KZ1000P
06 Dec 2009 13:58 - 06 Dec 2009 13:59 #337806
by Martynbiker
Cool, Thanks, so it looks like I need to get myself a 1/4" drive universal joint and a 6 pack of patience. It doesnt help when I wear a size XXXL Glove, my hands are HUGE and it is tight in there.
I will post pics of me banging head on Garage floor and do a write up about it..... May as well give someone a laugh! :laugh:
Last edit: 06 Dec 2009 13:59 by Martynbiker.
