First Bike- Gas Dripping 84' engine 750
- robert1083
04 Dec 2009 10:50 #337474
by robert1083
First Bike- Gas Dripping 84' engine 750 was created by robert1083
Hello. I just purchased a 1983 kz750 ltd, that actually has an engine from a 1984. It has 16k miles. The seller said that the carbs had just been tuned and cleaned. Everything seemed good for the first week or so. I took it around the neighborhood a few times before putting it away for the winter. I haven't winterized it yet (will soon as I live in Illinois), but I noticed that the bike had started to leak gasoline. It appears it may be coming from the the first carb on the left side. What could be causing this if the carbs indeed were just tuned and cleaned? I only have a side stand, could that affect it? I'm looking into purchasing a center stand, and I was going to get some Sea Foam for the tank. I appreciate any input. Thank you
- 9am53
- homebrew, and some bbq
- Thank you received: 3
04 Dec 2009 11:02 #337480
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic First Bike- Gas Dripping 84' engine 750
Check to see that it's not coming from your fuel petcock, I am thinking that it sits under the tank somewhere above the #1 carb and may be dripping onto the carb.
'84 GPz900r
'71 CB350
- robert1083
04 Dec 2009 11:06 #337481
by robert1083
Replied by robert1083 on topic First Bike- Gas Dripping 84' engine 750
If it is coming from there, what would I have to do?
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 Dec 2009 11:09 - 04 Dec 2009 11:11 #337483
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic First Bike- Gas Dripping 84' engine 750
If the carbs are leaking gas, then the float valve seats were not properly cleaned, and gas is flowing past them, overflowing the bowl.
You are turning your fuel petcock off right...
A center stand won't make a difference, so its not necessary unless you really need it.
you can remove the tank from the bike, and drain the carbs to ensure that fuel doesnt get into the engine.
Then fill the tank, and add some stabil, and store it away for next season.
May as well take the carbs off the bike then, and clean them yourself. It very easy, and they shouldnt be horrible if you've been riding the bike ok.
Lots of carb cleaning and float valve polishing instructions can be found with the search function here.
Cheers, good luck.
Cheers, good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 04 Dec 2009 11:11 by TeK9iNe.
- Thank you received: 2098
04 Dec 2009 11:23 - 04 Dec 2009 11:32 #337487
by Patton
Replied by Patton on topic First Bike- Gas Dripping 84' engine 750
Hello, Robert, and WELCOME to KZR!
We're glad you're here!
If there's no aftermarket in-line fuel filter, it's likely that the float needle/seat interface has become dirty enough to prevent full closure, regardless of how clean the carbs were beforehand.
Should be an in-line filter on each fuel line between petcock and carbs. Some carbs use a single fuel line, while others use dual fuel lines.
Would consider removing and flushing out the fuel tank.
And also removing, disassembling, and cleaning the petcock, including the internals, and fuel pick-up screens that normally protrude up inside the tank.
Good Luck!
Good Luck!
Last edit: 04 Dec 2009 11:32 by Patton.
04 Dec 2009 11:31 #337489
by Patton
If needed, may click these links to see a couple of the in-line fuel filters available from Z1 Enterprises.
www.z1enterprises.com/detail.aspx?ID=293
www.z1enterprises.com/detail.aspx?ID=3289
Good Luck!
Good Luck!
- robert1083
04 Dec 2009 11:39 #337493
by robert1083
It does have one of those in-line fuel filters.
04 Dec 2009 11:54 #337499
by Patton
Question -- do these carbs have overflow drain tubes attached to undersides of floatbowls and routed to exit underneath the bike?
If so, the leakage might be due to a dirty float valve, which might possibly be flushed clean by removing the floatbowl drain screw and allowing some fuel to flow through the carb.
This is a quick and easy first effort, which doesn't entail removing the carbs from the engine.
Would use a shop rag to catch the fuel as it escapes from the drain hole.
Good Luck!
Good Luck!
- timebomb33
- Thank you received: 10
04 Dec 2009 11:55 #337500
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic First Bike- Gas Dripping 84' engine 750
on a 20 year old plus machine things wear out it sounds to me like a petcock problem or worn needles and seats or a spring in a needles has weakend the problem your having won't have anything to do with getting the carbs clean unless they change the float settings which if set to high could cause a problem is thleak happening out of the vent line or from the carb bowl gasket surface.
- dejavoodo41
- Thank you received: 14
06 Dec 2009 17:26 #337846
by dejavoodo41
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Replied by dejavoodo41 on topic First Bike- Gas Dripping 84' engine 750
I had the same problem with my bike and it turned out to be the pingle petcock that was on the bike when I bought it. Once I replaced it I havent had any more problems.
- dejavoodo41
06 Dec 2009 17:28 #337848
by dejavoodo41
- chrispysaki
07 Dec 2009 09:35 #337922
by chrispysaki
Replied by chrispysaki on topic First Bike- Gas Dripping 84' engine 750
It might also be a small crack in the overflow tubes. That was the problem with my float bowl leak.
