greetings from Finland..!
  • ritiavanne
  • Topic Author
  • lets' take what's coming
01 Dec 2009 10:30 #336864 by ritiavanne
greetings from Finland..! was created by ritiavanne
Hi bros!
Newbie in this site and question at start B)
Does anybody have Wiseco K1076 kit instruction sheet/paperworks remain?
What I need to know is piston-to-wall clearance and... well alllll what should be known before get block bored and engine re-assembled.
My English is "practical english in practis" - so what :laugh:
Will appreciate any information !!!
-pete-
Z1000R-2, KZT00R-006394
  • unomike
  • Biker for 40 years.
01 Dec 2009 10:39 #336865 by unomike
Replied by unomike on topic greetings from Finland..!
Welcome ritiavanne,
I don't have the sheet you are looking for, but someone here does. And I'm sure of that. Others will come by shortly and welcome you to the forum and help you out. If not, then start a new topic with what you are looking for in the headline. That is sure to generate the help you are looking for. Be specific on the year, model and engine size you need this for. Your english is good to go here.
Own: 1980 Kaw KZ1300,Stage 1 kit,K&N pods
1972 Harley Davidson XHL Sportster, 1972 Suzuki T500, 1974 Hodaka 125 Dirt Squirt, 1980 Honda 250 VTR, 1983 Yamaha 750 seca and a 1974 yamaha GT80 for my son.
Bristol, Tennessee. USA
01 Dec 2009 13:30 #336881 by Tommotbird
Replied by Tommotbird on topic greetings from Finland..!
Welcome to the site Thor ( you are all called that in Finland aren't you?)
Best wishes from the UK
Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
01 Dec 2009 14:25 - 01 Dec 2009 14:50 #336893 by bountyhunter
Replied by bountyhunter on topic greetings from Finland..!
Only if they have a bent seat pan....
Last edit: 01 Dec 2009 14:50 by bountyhunter.
01 Dec 2009 14:46 - 01 Dec 2009 14:52 #336896 by bountyhunter
ritiavanne wrote:
Hi bros!
-pete-
If you were here I could direct you to a machine shop pro who could put his calipers on the pistons and know the answer in a half second. You will want to number the pistons and keep them in order. A machine pro will cut each hole to match the piston, not just generic size.
FYI: nominal piston to cylinder clearance (factory spec) for my 750 twin is .04 - .07mm which I believe is about 1.5 to 2.8 thousanths of an inch. I know when they bored mine, they kept it on the tight end of that spec.
Twins have big diameter pistons so the clearance spec on a four hole is probably a bit tighter since they don't have to allow as much for expansion outward on the piston and inward on the sleeve. My guess would be about .001" - .002", but that's basically just a guess based on comparable sizing.
Last edit: 01 Dec 2009 14:52 by bountyhunter.
01 Dec 2009 15:16 - 01 Dec 2009 15:17 #336899 by OnkelB
Replied by OnkelB on topic greetings from Finland..!
Hi Pete, welcome aboard.
We have at least one other member from Finland here, what's even better is that he also happens to own an R2.
His online name here is Z1109R Fin - below is a link to one thread he posted in, when you get to the thread just click the PM button to send him a personal message. He's a really nice guy who knows a lot about these bikes, I'm sure he can help you out or point you in the right direction and in your own language too.
CLICK
Send me a pm if he doesn't answer, I know where to get hold of him.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 01 Dec 2009 15:17 by OnkelB.
  • TeK9iNe
  • What did you do!?!
01 Dec 2009 16:30 #336904 by TeK9iNe
Replied by TeK9iNe on topic greetings from Finland..!
Welcome!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • trianglelaguna
01 Dec 2009 18:23 #336953 by trianglelaguna
Replied by trianglelaguna on topic greetings from Finland..!
welcome...that will be a good engine i bet.....others will have the info...contact wiesco.com direct to get links???
welcome...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • kano
  • Not Another Bloody Limey!
01 Dec 2009 18:34 #336960 by kano
Replied by kano on topic greetings from Finland..!
contact wiesco.com
Pete has tried so have i on his behalf that's why i sent him over here becouse of the huge collection of knowledge here....
  • ritiavanne
  • Topic Author
02 Dec 2009 01:34 - 02 Dec 2009 01:35 #337016 by ritiavanne
Replied by ritiavanne on topic greetings from Finland..!
Thanks for wellcomin!
Yes I know the pistons should be measured individually 'n make holes grounded to that.
Like "kano" says I've tried to contact Wiseco via e-mail - no answer what so ever.. only automatic one to turn local dealer. They don't have knowledge.. about anything :angry:
I've consult with one machinerist.. so I think everything goes well.
No hurry what so ever... next season is far away :( :(
No Thors here... only SISU
-pete-
Last edit: 02 Dec 2009 01:35 by ritiavanne.
  • larrycavan
  • Visitor
02 Dec 2009 02:42 #337018 by larrycavan
02 Dec 2009 08:02 #337042 by 531blackbanshee
Replied by 531blackbanshee on topic greetings from Finland..!
i have a wiseco 1075 kit at home with the paperwork.i can look tonight and see what it says(if i remember).i bore and hone m/c engines and have for several thousand holes and many,many years.forged pistons have to have a lil more clearance for expansion than cast pistons.wiseco will call for .003 thousandths clearance,i would set them up for someone i knew would/could break it in properly at .0025 thousandths.hth,
leon holmes
