cam chain tensioners
- 81kz550b2
Re: cam chain tensioners
27 Nov 2009 06:17
loudhvx wrote:
txturbo wrote:
The 550 tensioner is slightly different. It doesn't have the little side bolt like on the 750's.
Yeah, should have mentioned like Bill did, synchronizing the carbs will go a very long way to quieting down the cam chain rattle and the primary chain slap (louder clunking down low in the motor, usually loud when idling cold).
Primary chain slack is a nice thought as well. I changed a primary chain once on a 750, but that one was "slipping". When accelerating hard from relatively low revs you could hear it slipping over the sprockets. No one really believed the primary chain could be worn out, but eventually it turned out it was. I took it apart and the chain really was way too long for the sprockets. There could be a stage prior to that in which it rattles a lot in a cold engine...I shall make a ride this weekend I guess to see if it gets better with a warm engine.
1981 kz550b2
1984 kz750E (Turbo)
1989 GPz1000RX (Burnt down on the German Autobahn...)
Enschede
Netherlands
1984 kz750E (Turbo)
Enschede
Netherlands
- bill_wilcox100
27 Nov 2009 06:28 - 27 Nov 2009 06:35
81kz550b2, as you said you know your bike best... and I have never had a Cam Chain problem so I can't go there.
On my bike, I noticed a day-and-night difference between the Mechanical sync method and the Vacuum Gauge sync method... buts that's my bike...
Or maybe my Mechanical syncing sucks big lemons. :laugh:
Best of success.
Bill
PS
BTW, any chance you can add your year, model and location to your signature... it's considered real friendly and a member near you may be available for help.
Bill
Best of success.
Bill
PS
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Upgrades:
Montreal, Canada
Last edit: 27 Nov 2009 06:35 by bill_wilcox100.
- YUKABODOS
27 Nov 2009 06:50
I have an idea, why not adjust the cam chain AND sync the carbs.
- TeK9iNe
- What did you do!?!
27 Nov 2009 07:43 - 27 Nov 2009 07:47
81kz550b2 wrote:
These bikes are quite sensitive to vacuum differences, especially from engine age (wear and tear/minor compression changes).
If you have vacuum gauges, its really easy to do and theres lots of info here in the filebase. Strongly recommended!
Yeah and mechanical syncing does suck. Its just a prep for vacuum synching.
I approve this message.
PS
Got access to vacuum gauges?
Bill
got a set yes, but I don't believe this is the problem. I know this bike quite well and would be surprised if the carbs are way out of sync. Unless the bike is very sensitive to the slightest unsynchronisation I don't think this is it it. I will think about it though and get it checked, to make sure.
Fer damn sure homes.I have an idea, why not adjust the cam chain AND sync the carbs.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 27 Nov 2009 07:47 by TeK9iNe.
- 81kz550b2
28 Nov 2009 06:06
bill_wilcox100 wrote:
I will pimp my profile
See if I can get some pics on here as well.
Cheers!
Dirk
PS
Bill
Cheers!
Dirk
1981 kz550b2
1984 kz750E (Turbo)
Enschede
Netherlands
1984 kz750E (Turbo)
Enschede
Netherlands
- BCbikes
20 Apr 2014 18:54
is there any info on how to properly adjust the manual cam chain pensioner? i just did a top en rebuild .lapped the valves and adjusted the timing. im pretty confident its all correct. even the timing. however i do have some engine noise while idleing. especially cold. once the bike is moving i dont hear it. could this be because its too loose or too tight? how do i know to tight to go?
1980 kz550a
20 Apr 2014 19:58 - 21 Apr 2014 08:54
If you know what brand your tensioner is, try searching that site for the instructions.
In general, you're supposed to turn in the tensioner by hand until hard to turn, then back it out ~1/4 turn or so, then tighten the locknut. I would probably loosen it first, then do the adjustment as per the instructions.
Last edit: 21 Apr 2014 08:54 by martin_csr.
- zukdave
20 Apr 2014 20:17
Just call that dude Rob that work's for Jay and get the shit you need..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
