- Thank you received: 35
Dazed and Confused
- moneypit
new rings, head (ebay buy) checked by local shop,
they said it was fine, finnally get it togeather and NO compression on #3 NOT ANY PERIOD. Oil down the plug hole NO change. Compression checked just by putting thumb over plug hole. Lost my comp tester to thief:angry:
I can see the valves and they look good (thruogh the plug hole) Pulled cover today and cams and buckets look
good. #3 exhaust bucket rotates when turning over with
kick lever and can spin the bucket when lobe is away from shim, valve clearances may be a little tight over all .03mm on that shim. Changed coils on that cyl. no change,
Changed carbs from 29 smoothbores to 26s still no
change
Help $$
2-76 kz900
St Paul MN
- dragnkaw1428
Andy
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- moneypit
And I know I have all rings installed.
Okatar you forgot the :laugh: after your post :laugh: :laugh:
I useed to have a plug insert for an air compressor it vanished with my comp. tester:angry:
Thanks guys to bad the weather here is getting cold now may not get to it till spring I dont want the cylinders open to a moist garage all winter
2-76 kz900
St Paul MN
- racer54
- Thank you received: 114
- moneypit
2-76 kz900
St Paul MN
- keith1
- Thank you received: 2
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
When assembling the engine, was it possible that the camshafts were out of time with the crankshaft, and the engine rotated somewhat? If this bent a valve on #3 cylinder, then you could have clearance between the bucket and the cam, but the valve would not be sealing at all, but still consistently closing. Did you have to change shims drastically for cylinder #3?
Do like BSKZ650 suggested and use compressed air to see where the leakage is going. Hope the weather allows you to do the work and not wait until winter is over. Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
- Thank you received: 2098
I rebuilt my 76 900 motor last winter bored to 1015,
change
Help $$
NO compression on #3...#3 exhaust bucket rotates when turning over with kick lever and can spin the bucket when lobe is away from shim....
What about the intake clearance? Is there at least some minimal clearance on intake #3? Just wanting to confirm.
Would consider taking a ride "on three cylinders" with idea of possibly blowing away any carbon speck that might be interfering with complete seal of a #3 valve seat.
Am also wondering whether the local shop was correct when opining that the head was fine. Was each valve checked to assure it fully sealed in the seat when closed?
Good Luck!
- moneypit
It ran 15 years ago Ive owned it since 83 parked it because its hard to take the kid to daycare?school on it:laugh:did this motor ever run?...how did you find out #3 had no compression?.....no pro, but it sounds like the e-bay head might be suspect.......interesting........
Had it running thought it was carbs when noticed cold pipe
checked spark OK changed carbs still cold pulled plug and put thumb over plug hole and kicked it and NO compression:angry:
2-76 kz900
St Paul MN
- moneypit
I took pics of cam timing could post but that would mean multiple pic post dont have photobucket account yet it all looked goodmoneypit:
2-76 kz900
St Paul MN
