what's best way to remove old gasket?
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
20 Nov 2009 17:20
The clutch cover's been taken off and I always used a chisel to scrape off the old gaskets when I was a kid.
That was dumb, as the aluminum edges of the gasket surfaces on the motor are no match for a hardened steel chisel.
So now that I'm working on bikes again *and* am a bit wiser (at least wise enough to ask) -- what's the best way, the best tool and/or solvent (?) product to remove
gaskets from gasket sealing surfaces on engines without
damaging the engine's metal edge?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- PLUMMEN
Re: what's best way to remove old gasket?
20 Nov 2009 17:34 - 20 Nov 2009 17:45
oven cleaner and a plasic putty knife
Last edit: 20 Nov 2009 17:45 by PLUMMEN.
- KZQ
- Administrator
20 Nov 2009 18:04
Way to go Jimmy!
I was going to say a steel putty knife with softened corners. Never thought about oven cleaner.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Locozuna
20 Nov 2009 18:19
I used store bought gasket remover and it worked good. It is probably just oven cleaner tho. :laugh: I used a xacto chisel blade. Keep the bevel down so it doesn't want to dig. I will try oven cleaner and a plastic scraper next time. Worth a shot.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- newOld_kz1000
20 Nov 2009 20:25
Sounds perfect, have not tried it, sounds excellent, I just don't want to damage the mating surface.
thanks!
thanks!
- MFolks
20 Nov 2009 21:20
A piece of sharpened Lexan or Plexiglass and oven cleaner(be careful around anodized parts as it will remove the coating)should have the old gasket off.
- sr man
- Hawk
20 Nov 2009 21:39
I used a box cutter razer but I have been deburring machined parts (been a machinst for 10 years and not a button pusher the real deal) so if your good u can do it and if u nick something just sand off the burr or file it
Untill the sun dont shine
1978 kz650sr with 1980 E Ltd moter and carbs
Dyna Electronic Ignition
Dyna 3 Ohm Coils
Dyna wires
Progressive Springs Front Springs and
- and Rear Springs/Shocks
Wichita Kansas
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
- bountyhunter
20 Nov 2009 22:54
Brake fluid will dissolve most gaskets. I use a single sided razor blade to scrape the flanges, then polish with scotchbrite pad.
- newOld_kz1000
20 Nov 2009 23:51
bountyhunter wrote:
Thanks, was worried about getting oven cleaner on the anodized parts of the engine cases -- the brake fluid will be much easier to control as it's applied -- thanks.
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
21 Nov 2009 03:31
right angle die grinder with a scotchbrite pad.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
1984 ZX1100 A2 GPz
1984 ZX900
1969 Camaro SS
1966 Impala
- newOld_kz1000
21 Nov 2009 08:45
txturbo wrote:
I'm not familiar with this tool, a 'right angle die grinder' -- is it a handheld tool that has a right-angled drill head on it and you attach round buffing wheels or grinding pads onto it? (just guessing here....)
- sr man
- Hawk
21 Nov 2009 09:04
I would use a drill its safer with scotchbrite pad
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
Dyna 3 Ohm Coils
Dyna wires
Wichita Kansas
