Apparently Im too dumb to install clutch cable
13 Nov 2009 18:29 #333526 by Patton
keith1 is absolutely correct. :cheer:
I overlooked splandman saying it was the 76. :blush:
Gong! :laugh:
Good Luck !:)
13 Nov 2009 18:55 - 13 Nov 2009 19:08 #333533 by Splandman
Replied by Splandman on topic Apparently Im too dumb to install clutch cable
alright, i have the manual for the 76 900 right in front of me.....its pretty much what i posted loosen the locknut and unscrew 3-4 turns....now tighten it untill its hard to turn and back it out 1/2 turn...tighten locknut....do mid adjuster as noted previously and manual is looking for 1/16 to 1/8 at lever.....this is right out of manual for 73-77 900/1000 cc fours ...hope it helps
Decided I needed to go do this or it would drive me nuts. Took no time at all. I had the thing way too tight. I reset it, and cranked it up, put it in gear and the clutch felt good. I didnt go ride but let it out in first in the garage a couple of times and it felt fine.
Thanks a lot for the help.
Current Bikes
1980 KZ1000E
Last edit: 13 Nov 2009 19:08 by Splandman.
14 Nov 2009 04:22 #333572 by Old Man Rock
Replied by Old Man Rock on topic Apparently Im too dumb to install clutch cable
"now tighten it until its hard to turn and back it out 1/2 turn" .... A little tip that I learned from Grumpy ass Plummen....
I have a '76 KZ900 setup.... As in my book (above sentence), this didn't work out well either... Hell I would be at the very end of the clutch lever release before it would engage, no matter what I did with the cable adjustments, it just wasn't right....
Trial & error, re-adjustments you name it... Just wasn't ideal.
Don't tighten the screw until hard... Tighten just until you feel it make contact with the push rod... Now back it out an ~ 1/8 turn or so, then lock her down with the nut....
Now make your cable adjustments...
This now allowed for proper operations & my preferred clutch lever action where it now engages ~ 1/2 the clutch lever pull...
Give it a try.... may work for you as well... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
