What's this oil leak?
29 Oct 2009 18:43 - 20 Feb 2013 19:04 #330396 by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 19:04 by H1Vindicator.
29 Oct 2009 20:00 - 29 Oct 2009 20:02 #330422 by polkat
Replied by polkat on topic What's this oil leak?
In your pic I have circled in red the bolt I think you were talking about. When I first got the bike, I thought that was another oil drain, but it's too high.
The screw I have circled in blue may be the one I'm talking about, though I thought it was further under (too dark out to check now).
The brown arrow shows the path of the oil leak, which is coming from somewere above where the top of the pic stops. Though it is near the split between the stator cover and the engine case, it is not coming from there.
I'll try to get my own pic of this tomorrow. Thanks!
Last edit: 29 Oct 2009 20:02 by polkat.
30 Oct 2009 06:48 #330469 by JMKZHI
Replied by JMKZHI on topic What's this oil leak?
The phillips head screw is for the stator cover.
30 Oct 2009 10:17 #330492 by JR
Replied by JR on topic What's this oil leak?
Best thing to do to identify where exactly the leak is coming from is to clean the area well with simple green or dish soap and water, dry it off , put baby powder all over the area, start the bike and watch.
until you do that it's all speculation. Oil could be coming from a lot of places like cyinder base gasket. stator cover etc etc.
Or if it's not a big deal just learn to live with it. I got a few small seeps and as long as they dont get any worse it's not worth my while tearing down the motor just to fix them
Good luck
  • txturbo
  • Ex-Kawasaki Mechanic 1981-1985
02 Nov 2009 04:32 - 02 Nov 2009 04:35 #331036 by txturbo
Replied by txturbo on topic What's this oil leak?
That bolt circled in red is one of the bolts tht holds the cases together.You will just have to clean everything reall good and start the bike and watch where it leaks from.It could be coming from a lot of different places.Most likely its coming from one of the o-rings between the top of the case and the bottom of the cylinder.polkat wrote:
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
Last edit: 02 Nov 2009 04:35 by txturbo.
02 Nov 2009 05:40 #331044 by Bluemeanie
Replied by Bluemeanie on topic What's this oil leak?
I agree with txturbo. At work I'll clean an engine then run it on the rack while watching for leak. If not showing up will have customer drive it for a couple days and then return. Depends weather it's a pressure leak or not. Let us know... ;)
