Crack in cylinder head when tacho gear removed
- Arnold
Re: Crack in cylinder head when tacho gear removed
21 Nov 2009 12:43 - 21 Nov 2009 12:44
Check out my project at:
kzrider.com/forum/11-projects/550823-ret...100-82-goes-z1-clone
Last edit: 21 Nov 2009 12:44 by Arnold.
- otakar
21 Nov 2009 13:08 - 21 Nov 2009 13:14
In the military we used "Smooth-On" Metal Set. It is much better than JB weld. It was the only e-Poxy allowed to be used on aircraft hot areas. Metal Set is much better than JB Weld. JB Weld is Iron filled and will cause corrosion on Aluminum and fall off at high temperatures. Metal Set is Titanium Oxide filled and is designed for this kind of stuff. I used Metal Set on quite a few engine cases and they held indefinitely. BUT I don't know if I would trust an epoxy in the hottest area of the engine. I would either solder it with Zinc sticks or have it TIG welded. If you loose that chunk while on the road you can loose most of your oil. We all know that this stupid thing always leaks, even under the best of circumstances. How much do you think it will leak with that chunk missing on the road?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Nov 2009 13:14 by otakar.
- Arnold
22 Nov 2009 08:06
Well...we will find out this summer if it holds up or not.
There is no stress on this area, might get a bit hot but it´s still quite far from the cylinders.
Will fill with liquid gasket before I put the tacho-drive in and hopefully get it sealed.
Is Metal Set available for civil use ?
I wouldn´t get on a plane where engine parts was fixed with any chemical weld
- otakar
22 Nov 2009 08:09
If you put liquid gasket in the drive before you install it, you will never be able to remove it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Arnold
22 Nov 2009 08:20
You got a point...
But how get it sealed otherwise...? The O-ring dont do muck good..
I dont see a reason to get the tacho-drive out again unless the drive-screw wears out. And that will take a long long time.
Even considered putting some JBWeld in when I do final assembly...that will get it sealed
But this is a bit over the top...
22 Nov 2009 11:39 - 22 Nov 2009 11:41
Arnold wrote:
Am thinking the tach drive housing must be removed to replace its o-ring and also the small spring loaded rubber seal inside the housing through which the tach drive shaft rotates.
The o-ring is to prevent oil from escaping around the housing where the housing fits into the head.
The shaft seal inside the housing is to prevent oil from escaping around the shaft.
Would suggest a small dab of Permatex High Temp Copper silicone (from tube -- not spray) at the area where the o-ring can't seal.
Imo, it's important to retain ability to remove the tach drive housing without some super-human effort. So go sparingly as possible with the silicone seal.
The JB Weld repair looks okay.
Good Luck!
You got a point...
Good Luck!
Last edit: 22 Nov 2009 11:41 by Patton.
- Arnold
24 Nov 2009 12:57
Thax for the intel Pat..
Will keep you update about the outcome.
Just have to post a pic of my bike, will look better after this winter rebuild.
- Arnold
11 Dec 2009 13:31
Outcome:
The engine head overhauled:
* Valves ground in
* New valv seals
* Glas blastered
* Repainted in black
* Valves ground in
* New valv seals
* Glas blastered
11 Dec 2009 13:44
The head looks really nice, and especially the polished edges of cooling fins.
Good Luck!
Good Luck!
- Arnold
12 Dec 2009 01:26
- Arnold
02 Jan 2010 15:25
- Arnold
02 Jan 2010 15:27
