Clutch, transmission or what??
  • clutch
  • Topic Author
  • I wish I had a tad more patience to do it better!
12 Nov 2009 16:49 #333184 by clutch
Replied by clutch on topic Clutch, transmission or what??
Thanks for all the help guys. Z1 doesn't carry the nuts, but they ordered them for me! The clutch is all back together after purchasing an impact wrench (I knew my compressor would come in handy someday!), and the front sprocket is back on. I had some issues removing the master link on the chain, but finally got it. All that is left is to reinstall and relube the chain, after fixing a pinhole leak in the bearing cap! Sunday is supposed to be nice here, and I should be ready to ride again by then!!! :-D
~Clutch
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
12 Nov 2009 16:54 #333189 by PLUMMEN
Replied by PLUMMEN on topic Clutch, transmission or what??
bountyhunter wrote:
clutch wrote:
Ok. I will definitely check the engine sprocket. The rear sprocket is fine. I did run into an issue dissasembling the clutch to check everything on that side. How do you hold the inner hub still to remove the clutch hub nut?
Clutch holder tool. Looks like a big pair of vise-grips with right angle ends on them.
or take an old steel clutch plate and weld a handle on to it B)
  • clutch
  • Topic Author
13 Nov 2009 09:09 #333418 by clutch
Great idea! I don't have a welder and actually avoid doing any work that will require me to buy welding tools. I ended up buying the clutch holder from Z1...they are the bomb! :)
Wish List:
Z1 (need I...
