Clutch, transmission or what??
  • clutch
  • Topic Author
  • I wish I had a tad more patience to do it better!
23 Oct 2009 00:39 #329093 by clutch
Clutch, transmission or what?? was created by clutch
So I decided to go for a ride on my 82 kz750 e3 before work today since it was nice out. I got a few miles before I realized my front brakes were sticking. Stopped at the nearest auto store to fix the issue and resumed my ride. I probably rode for another 30.minutes and decided to stop at a store. Turning into the shopping center, I downshifted to first, heard a slight grinding noise and quickly realized I had no drive system.
So I parked the bike and went to work. Now its almost 4 am and I am sitting here waiting for the AAA tow. Anyone have a theory about what may have happened? The clutch has been slipping a bit lately in the higher rpms, so that's what I think it is. Anyone have another theory?
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
23 Oct 2009 03:56 - 23 Oct 2009 03:58 #329096 by Patton
Replied by Patton on topic Clutch, transmission or what??
If not already done, could perform clutch pushrod adjustment.
And also adjust slack in clutch cable.
Any teeth remaining on the rear drive sprocket?
Good Luck! :)
Last edit: 23 Oct 2009 03:58 by Patton.
23 Oct 2009 06:27 #329110 by RonKZ650
Replied by RonKZ650 on topic Clutch, transmission or what??
Your countershaft sprocket nut has come off and the sprocket slid off the splines. Common problem. Happens from using aftermarket sprockets that have no provision for the safety lock tab washer.
23 Oct 2009 07:40 #329120 by timebomb33
Replied by timebomb33 on topic Clutch, transmission or what??
like ron said check the slack in the drive chain if it seems like it quite a bit excessive pull off the sprocket cover and check your front sprocket it probably has come off quite a comman thing actually.
I THINK MY POWERBAND BROKE
  • clutch
  • Topic Author
26 Oct 2009 20:28 #329860 by clutch
Replied by clutch on topic Clutch, transmission or what??
Ok. I will definitely check the engine sprocket. The rear sprocket is fine. I did run into an issue dissasembling the clutch to check everything on that side. How do you hold the inner hub still to remove the clutch hub nut? The pressure plate, springs, and plates are all ok but figured I would have a good look behind if I can get the darn thing off!!! I did manage to pick up the proper 30mm socket to remove the nut, but none of y vice grips or anything else I have will hold the hub still to remove it!!!!
Wish List:
Z1 (need I...
  • clutch
  • Topic Author
26 Oct 2009 20:54 #329864 by clutch
RIGHT ON THE MONEY! Now I just need to find a replacement nut or three and figure out how to get the clutch hub and basket out to replace the basket I broke (trying to remove that darn clutch hub nut!) with the good one in my spare engine!!!
Wish List:
Z1 (need I...
  • clutch
  • Topic Author
26 Oct 2009 20:58 #329865 by clutch
Answered my own question. I love Z1 Enterprises!!! :-D
Wish List:
Z1 (need I...
26 Oct 2009 21:02 #329866 by timebomb33
thebest way to hold the basket is with a clutch hub holder from motion pro also don't try using a ratchet or breaker bar on it use an impact gun either air or electric the shock from the gun will break it loose and all you will need is to hold it with your hand. and when your putting the nut back on the output shaft sprocket or the clutch hub clean the threads real well and put red lock tight on the threads it will make it tougher to fall off next time also check the nut from time to time. i always carry an extra nut with me if i'm racing or going on a long trip. just for occasions such as this.
  • clutch
  • Topic Author
27 Oct 2009 09:21 #329927 by clutch
Where do you get the nuts? I can't find them anywhere online other than BikeBandit.com (whom I don't shop from anymore).
Wish List:
Z1 (need I...
27 Oct 2009 11:17 #329937 by bountyhunter
Replied by bountyhunter on topic Clutch, transmission or what??
Clutch holder tool. Looks like a big pair of vise-grips with right angle ends on them.
  • clutch
  • Topic Author
27 Oct 2009 11:29 #329939 by clutch
Thanks Bounty Hunter. Any idea where to find a replacement nut for the countershaft sprocket???
Wish List:
Z1 (need I...
27 Oct 2009 11:45 #329941 by timebomb33
go to your local kawasaki dealer they can get them for you and while your at it get a couple of extras
