84 GPZ AND 84 LTD1100 head
- mkawasaki23
23 Oct 2009 08:10 #329123
by mkawasaki23
Replied by mkawasaki23 on topic 84 GPZ AND 84 LTD1100 head
You can use KZ pistons on the J model or the 81-82 GPZ, but you can't use them on the 83-84 GPZ. The 83-84 GPZ has the bathtub style combustion chambers and the valve angles are different, so you have to use pistons for the 83-84. The 83-84 GPZ also has 18mm wrist pins but MTC makes there pistons for the 83-84 GPZ with 17mm wrist pin holes. If you need the 18mm wrist pin holes they just hone them out to 18mm. Sorry I keep refering to the 83-84 GPZ, your 1100LTD head is the same. So to answer your question, you can't use the J model pistons you have. You have to order pistons for the 83-84 GPZ1100 to use that 1100LTD head you have.
- PLUMMEN
- Thank you received: 104
23 Oct 2009 08:25 #329126
by PLUMMEN
Replied by PLUMMEN on topic 84 GPZ AND 84 LTD1100 head
kind of what i thought
- larrycavan
- Visitor
25 Oct 2009 18:10 #329611
by larrycavan
Replied by larrycavan on topic 84 GPZ AND 84 LTD1100 head
That head was first used in 83 on the monoshock GPz11. The LTD got that head in 84 & 85.
The 83 LTD was plain Jane J motor. Nothing special about that one.
Can't find my old notes on the bathtub chamber heads for volume. Somebody cc one and let me know. I'll add it the KZData page with the flow and valve info.
Standard J head is 39cc and KZ is 34.5cc chamber volume.
Whenever possible, shim on top is the way to go for street bikes. GPz11 cams work fine with S.O.T. setup.
I've had KZ650 motors come through that were converted to S.O.T and run thousands of miles like that.
Cam Motion has 4 really nice grinds for S.O.T.
Jay's got the K410 grind and Web has a bunch of them.
Here's a couple Web street cam. Always check lobe clearances.
Grind lift D@.020 D@.050 D@.100
483 .395 266° 242° 216°
540 .384 272° 248° 222°
- School Teacher
25 Oct 2009 22:47 #329666
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic 84 GPZ AND 84 LTD1100 head
School Teacher wrote:
Larry any comment on what pistons to run.
I have the ltd head and like it better because it is silver. i will end up putting it on a KZ lower end what style pistons should i run? I have a set of 1200 wiseco j pistons(10.5-1) could i use those or do i need something different.
1980 kz1000G1
