84 GPZ AND 84 LTD1100 head
- School Teacher
21 Oct 2009 16:00
so the casting is the same and the gpz has under buckets what about cams? it i get the ltd head would i need to change any thing on them to use under buckets?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- timebomb33
Re: 84 GPZ AND 84 LTD1100 head
21 Oct 2009 18:57
the combustion chambers are completly different so if your installing the ltd head on the gpz block you may have to change pistons that would be my big concern in order to change from shim over to shim under you will have to use all the gpz componets depending on cam lift you may have to clearance the bucket bores and possibly the head it self.
I THINK MY POWERBAND BROKE
- School Teacher
21 Oct 2009 19:03
the 84-85 ltd have the same combustion camber shape and the 83-85 gpz
1980 kz1000G1
1980 kz1000G1
- timebomb33
21 Oct 2009 19:24
sorry i thought they were different.
- kawsakiman
21 Oct 2009 20:20
a 84 ltd 1100 is a gpz motor.
for those of us that own one, we have a kick ass kawasaki motor. 102 factory hp.
to use under buckets you would need to change the retainers, that's it.
you can not use kz pistons in a gpz motor. they are different.
the cams are a little different but who uses stock cams?
if anyone wants stock kz cams, just pm me.
i have a ton for just shipping.
schoolteacher is right.
kawasaki put these motors in cruisers as a shakedown test before going all out.
- School Teacher
21 Oct 2009 20:22
no prob, i always value what you have to say and thankyou for helping so many people on this forum, I
1980 kz1000G1
1980 kz1000G1
- timebomb33
21 Oct 2009 20:42
to be perfectly honest i don't think ive ever seen an 84 ltd 1100 or the zn1100 up here or ever had the head off of one this info is good to know if i ever am looking for that style of head. now i have other options not just the late model gpz. they say if you don't learn something new everyday you may as well be dead, it look's as if im good for another one then. thanks for the info.
- School Teacher
21 Oct 2009 20:56
I have the ltd head and like it better because it is silver. i will end up putting it on a KZ lower end what style pistons should i run? I have a set of 1200 wiseco j pistons(10.5-1) could i use those or do i need something different.
1980 kz1000G1
1980 kz1000G1
- mark1122
- Keep twisting it
22 Oct 2009 15:16
the gpz head is the bigger, bathtub shape chamber , the j is round. the gpz will give u about .5 less compresion ratio when compaired to the j chamber.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
22 Oct 2009 15:33
will kz pistons work with the bathtub chambers or do you need something special made?
- timebomb33
22 Oct 2009 21:19
mabye larry or jay can help or john can help with this question what are the combustion chamber size differences between the various styles of z1 kz j and gpz heads.
- kawsakiman
23 Oct 2009 05:56
PLUMMEN wrote:
you can use kz pistons with a gpz head but you really should fly cut the pistons first for bigger valve relief.
it has been said a hundred times here you will lose compression going that way. almost 2 points.
would make a killer turbo motor though.
