Power expectations for KZ750
- chrispysaki
Does that sound about right, or should my 1980 KZ750 be able to keep up? The triumph is really fast, and not many bikes keep up with it, but I figured I'd at least be able to keep pace with the Harley.
I'm running a 4-1 pipe, pods and upjetted three sizes for my mains and secondaries. All else is pretty much stock.
- soccerd31
81 kz750 ltd h2...... i was doin fine.... i would think you could keep up...?? bore it out?? redo your gear ratios??
1981 KZ750 LTD H2
- Tommotbird
I have a Triumph Thunderbird Sport 900 & a Legend TT 900.
Also have 3 x 750 KZ750Ltd's- great bikes but from a different I am afraid.
Handling- No chance!
Braking- No chance!
Power- No chance!
Price- Good chance!
Accept what you have and enjoy it!
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Tommotbird
Technology moves on & also yours is a 750cc.
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- chrispysaki
I'm thinking I might get a smaller rear sprocket to give it some better off-the-line pickup. Maybe some new carbs?? Anyone have any other ideas for easy, cheap mods that will improve performance?
My buddy's Triumph is really fast, so I didn't really expect to be able to keep pace with him. I can't believe how light his bike is, either. It looks a lot heavier, but probably weighs close to 100lbs less than mine.
- YUKABODOS
The boys are right though...tough when you give up 30 years and 150cc's.
Sort of like Chris Chelios still trying to play in the NHL.
- Thank you received: 2098
... thinking I might get a smaller rear sprocket to give it some better off-the-line pickup....
Larger - not smaller - rear sprocket usually improves off-the-line performance.
Might consider a one tooth smaller front (counter-shaft) sprocket instead of a larger rear sprocket. Usually produces a higher busier cruising rpm.
Good Luck!
- Thank you received: 2829
- PLUMMEN
- Thank you received: 104
id guess your running out of motor before 8500Are you windin you bike out to 8500rpm's when you change gears? Max horsepower for KZ are high. Wind it out and feel the surge of power.
- chrispysaki
Ed—I'm actually running the 750-four. Don't know if that makes any difference.
- 2006hhr
- nissanfiremike
