stupid head/block o-rings
- otakar
Are these used on the KZ900? Where are they located at?
No these are only used on the earlier "J" motors. This is why I do not think that they are that critical. Since they stopped using them again on the 1100s.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- otakar
www.parcoinc.com Orings Galor.Any shop that services hydraulic pumps and valves will either have the orings you need or will be able to get them cheap.bring an old one with you.or measure ID,OD and cross section.and give to the guys up at the top here
The problem is that these have an oval cross section and not a round one. That is what this whole debate is about. But I also believe that they might not even be necessary. So, just reuse the old ons.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
- otakar
I believe that that is the last "J" series motor that uses them. The ZN and ZX series motors no longer do, even though they are otherwise pretty much the same as your motor. When I rebuilt my 81 CSR1000 motor I used the top end from a 83 GPz1100 and it no longer had these "O" rings.My 1983 KZ1100 Spectre has them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- otakar
All you need is a oring that will provide around .015 to .020 thou of squish and fill the space required.Viton is best.std orings come in 0.100.200 300 ect series.Metrics are measured in mm.I would never reuse a oring Ive seen to many $100,000 dollar peices of equipment fail in the field after installation for just that reason.PAIN in the ass and want to kill the guy that did the rebuild.(if its there when i take it apart i want there when i put back together)If using Buna id go with 90 durometer.
These "O" rings were only used in 1981-1982 and some 1983 engines they were not used in the earlier engines and they stopped using them again in the ZX series engines in 83. From 84 on they were not used at all. There must be a reason that they were so short lived. The only exception to this rule are the police bikes. The engines in all of those was of the complete 1981 design.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Jeff.Saunders
All you need is a oring that will provide around .015 to .020 thou of squish and fill the space required...
Overall I agree - but with a big caveat. You must ensure the o-ring doesn't encroach on the oilway. If it does you can reduce oil flow. On an o-ring like this, I wouldn't want to take a chance on a regular round cross-section.
www.z1enterprises.com
Z1 Ent on Facebook,
- TeK9iNe
- What did you do!?!
- Thank you received: 28
"I was worried that they would be hard and crappy, but they were like new.".... :laugh:
Damn big man, I swear you're going to be gray/bald by the time your finished with this build.... :laugh: :laugh:
Not if I can help it.
He'll be melting rubber this summer! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
Than why are these "O" rings on so few models and not on older or newer ones?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
