- Thank you received: 104
Valve removal help, please!
- PLUMMEN
use an old deep socket with windows cut into it instead of pvc pipeI did this for the first time this summer and it is difficult. I have a big c clamp and a small pipe nipple that I notched out. my pipe is almost too small because I can barely get the keepers out past the pipe.
Anyway, I had to have my wife help me hold/turn/grab/etc. She helped me to remove and reinstall the keepers.
Sometimes another set of hands helps.
However a c clamp breaking is not good. Also, I don't think PVC is strong enough for this job, so be careful or get some pipe.
- APE Jay
- Banned
- Thank you received: 58
- PLUMMEN
- APE Jay
- Banned
Jay
- PLUMMEN
- Old Man Rock
- Thank you received: 225
Leave that to the experts for as already mentioned, expensive in OH SHIT factor and for a strong running motor with ideal, desired operations in power and intake air flows....
Naw, leave that one alone, worth every penny!
Just my 2 worthless cents....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- z1kzonly
- Thank you received: 540
Your fingers are priceless.
This is my collection of used shims, the shim tool, the pry bar and I use the hemostats for plucking out the shim.
All this stuff is over 30 years old.
We used to pass this stuff around the neighborhood.
After a missed shift, Friday night showing off.
I use laquer thinner and marvels mystery oil mixed for a cleaner and to see if there is any leakage through the valve seat afterwords, or to see if you have a bent valve with the head upside down on the bench.
- PLUMMEN
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- chrispysaki
I ended up not grinding the valves, but just cleaning them up a bunch. A little trick I figured out — only after hand scrubbing 7 out of the 8 - was to put the valves in my drill and turn them at a high speed while holding a scotch brite pad against them. It got off a lot, lot more gunk than just hand scrubbing, plus it took about 1/10 as long.
- timebomb33
I THINK MY POWERBAND BROKE
- wes_scooter
i laped mine in for a very tight seal when mine was apart. held liquid for 15 minutes with springs off...
76' kz900
70' yamaha R5
2006 wr450f
