How's it look to you?
- chrispysaki
03 Oct 2009 22:18 - 03 Oct 2009 22:19 #325353
by chrispysaki
How's it look to you? was created by chrispysaki
So I finally got my head off (man does my neck hurt!). I had a leak coming from the head, which I thought might have been the valve stem seals, but maybe the gasket. Turns out the gasket is in great shape - I could reuse it if I wanted. Anyway, I'm planning on replacing the valve seals, gaskets, etc. I think I probably need to lap the valves, since they're not sitting flush.
Here are the pics of the valves and the pistons. The exhaust valves are all white (as are the valve stems). Does that mean it's running lean? It was running with a 4-1 pipe with the original jets, and I recently added pods and upped the jets by three sizes, so if it is lean, I'm thinking it was probably a result of the previous configuration.
So, does anyone see anything here that you think I should be aware of or concerned about?
Thanks,
Chris
Thanks,
Chris
Last edit: 03 Oct 2009 22:19 by chrispysaki. Reason: looks like I need to upload separately
- chrispysaki
03 Oct 2009 22:20 #325354
by chrispysaki
Replied by chrispysaki on topic How's it look to you?
- chrispysaki
03 Oct 2009 22:22 #325355
by chrispysaki
- chrispysaki
03 Oct 2009 22:23 #325356
by chrispysaki
- chrispysaki
03 Oct 2009 22:23 #325357
by chrispysaki
- chrispysaki
03 Oct 2009 22:24 #325358
by chrispysaki
- chrispysaki
03 Oct 2009 22:24 #325359
by chrispysaki
- bountyhunter
- Thank you received: 337
03 Oct 2009 23:17 - 03 Oct 2009 23:20 #325362
by bountyhunter
Replied by bountyhunter on topic How's it look to you?
I thought whitish or very light tan exhaust valves was OK. Mine are always blackened with burned oil from valve seal leaks by the time I have to do the head, but that's not their proper color.:laugh:
Piston tops don't look bad.
Check the spark plugs to see if you were running lean.
Last edit: 03 Oct 2009 23:20 by bountyhunter.
- Mark Wing
- Thank you received: 22
04 Oct 2009 00:12 #325365
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic How's it look to you?
I think it looks fine.
Mark
Mark
Yorba Linda Cal.
- 9am53
- homebrew, and some bbq
04 Oct 2009 05:34 #325375
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
Replied by 9am53 on topic How's it look to you?
are you going to clean up that carbon before you put it back together?
'84 GPz900r
'71 CB350
- trianglelaguna
- Thank you received: 235
04 Oct 2009 05:46 #325379
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic How's it look to you?
heck i'd be tickled pink if by the time i open my motors they look that good....i think that is the coloration of a normal running gas engine...but others more qualified will better tell....oh...and nice quality on your pics..helps others to see your questioned area really well........good luck...
1976 KZ900
2003 ZX12R
2007 FZ1000
- Old Man Rock
- Thank you received: 225
04 Oct 2009 06:46 #325385
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic How's it look to you?
Exhaust valve coloring....
Pending motor build, head valve & porting, elevations, jetting, exhaust etc... may just be correct setup for that motor...
One thing for sure, with all 4 exhaust valves basically the same color, this also informs you you have all 4 carbs as well jetted & synced the same... Nice !
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
