kz750 cam tensioner
- DBINWI
30 Sep 2009 20:03 #324839
by DBINWI
kz750 cam tensioner was created by DBINWI
I just picked up a 1976 KZ 750 . 17000 miles showing on odometer. Could someone tell me how I could check the cam chain tension and adjustment.Is there anything else I should check before heading out for shakedown trip
Thanks
Thanks
- Johnj
30 Sep 2009 21:26 #324862
by Johnj
Veho vivo - Ago ut veho
Replied by Johnj on topic kz750 cam tensioner
1)remove contact breaker cover
2)remove cam chain tensioner cap and o-ring
3)Turn the crankshaft counter-clockwise (use a 17mm) while watching the tensioner pushrod. Keep turning the engine over counterclockwise until the rod at the center of the tensioner reaches its innermost position and stop. DO NOT TURN THE ENGINE CLOCKWISE.
4)Loosen the locknut and screw the pushrod guide until the ends of the pushrod guide and the pushrod are flush.
- Arnold
- Thank you received: 14
18 Oct 2009 02:15 #328157
by Arnold
Check out my project at:
kzrider.com/forum/11-projects/550823-ret...100-82-goes-z1-clone
Replied by Arnold on topic kz750 cam tensioner
Thanx for a good description.
Does it matter if the engine is hot or cold ?
I suspect tha ny cam chain is a bit slack since it rattles when engine is cold and runnin on low revs.
Hope some tension will help.
/Arnold
/Arnold
- hugo
- '92 Zephyr 750
- Thank you received: 71
18 Oct 2009 04:54 - 18 Oct 2009 05:04 #328160
by hugo
Replied by hugo on topic kz750 cam tensioner
You should do all this with engine cold. Most these engines rattle when they are cold, at idle. Mine rattles cold below 1500 rpm, but is OK when warmed up. The fact that they don't have a water jacket makes it more audible. With an automatic tensioner, there is really no adjustment. There is reset after you have disassembled it.
You could change the spring for a new one, or go with a manual. Some people say a manual tensioner makes it quieter, as you can simply make it tighter, but I, personally, am not so sure this does not promote more wear on the chain.
These engines also have a primary drive with not tensioner which may slap a bit. Kawasaki put a tensioner there on the last version of the KZ750 sold in the US; the ZR-7,to make it quieter and compete with the liquid cooled Suzy SV650.
Last edit: 18 Oct 2009 05:04 by hugo.
- tinlizzie37
18 Oct 2009 09:43 #328222
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic kz750 cam tensioner
Putting an automatic tensioner from a KZ after 1981 will solve the problem. They are a double wedge type and are foolproof. I had the same problem on my 650-E and it made it very quiet. Good luck. Bob
- Arnold
21 Oct 2009 14:28 - 21 Oct 2009 14:28 #328778
by Arnold
I saw that I had the automatic type so I could not adjust it. I still think it rattles a bit too much.
When I pulled the oil pan out I saw some bits of plastic probebly form the cam chain guides. Will replacing these reduce the rattle ?
[img size=(01-499)]H:\My Documents\My Pictures\Z750\Kawa 750 motor.jpg[/img]
Last edit: 21 Oct 2009 14:28 by Arnold.
