HIGH OIL CONSUMPTION
28 Sep 2009 21:27 #324550 by MBFMGP
HIGH OIL CONSUMPTION was created by MBFMGP
HI ALL,
ITS BEEN SOMETIME SINCE I WROTE ANYTHING BUT I NEED TO NOW.
I'VE GOT A 82 KZ1100D SPECTRE WITH 30000 MILES ON IT.
IT RUNS AND RIDES LIKE A DREAM BUT HAS ONE BIG PROBLEM.
IT BURNS A QUART OF OIL EVERY 200 MILES.
NOT A LOT OF SMOKE AND OK PERFORMANCE.
MY QUESTION; COULD THIS BE ANYTHING OTHER THAN BAD RINGS VALVES OR SOMETHING THAT REQUIRES A SERIOUS TEARDOWN???
THNAKS
FRED
29 Sep 2009 05:33 #324574 by chance
Replied by chance on topic HIGH OIL CONSUMPTION
Valve seals.. I doubt if it burning a quart every 200 miles..No leaks? A compression check would be in order..
29 Sep 2009 05:43 #324575 by BSKZ650
Replied by BSKZ650 on topic HIGH OIL CONSUMPTION
Thats a LOT of oil to be burning, yes on a compression check, also make sure the vent is not plugged up it could be causing high back pressure and causing oil use
77 ltd1000, current rider
76 kz900, just waiting
29 Sep 2009 07:06 #324589 by MBFMGP
Replied by MBFMGP on topic HIGH OIL CONSUMPTION
IT IS BURNING THAT MUCH OIL I CHECKED SEVERAL TIMES.
HOW DO I CHECK THE VENT ?
  • TeK9iNe
  • What did you do!?!
29 Sep 2009 07:06 - 29 Sep 2009 07:08 #324590 by TeK9iNe
Replied by TeK9iNe on topic HIGH OIL CONSUMPTION
Are you sure your losing that much oil?
You should check the oil the next day, after its all run back down into the pan and returned to the same temperature.
Some guys can be overfilling, checking the oil hot and seeing it low in the window. Well thats because its all still up in the head and all over.
Goodluck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 29 Sep 2009 07:08 by TeK9iNe.
29 Sep 2009 12:21 #324633 by PLUMMEN
Replied by PLUMMEN on topic HIGH OIL CONSUMPTION
pull your airfilter out of the airbox to see if its soaked with oil,if crankcase vent was plugged up it would definately be trying to push gaskets out to vent itself.id say scrub the motor down really good at the carwash and start looking for leaks,looks to me like theres a lot of oil around head gasket and basegasket area from your picture B)
29 Sep 2009 20:30 #324711 by MBFMGP
HONESTLY, I'M POSITIVE IT USES THAT MUCH .... ALWAYS CHECK COLD BEFORE I USE IT.
WISH I WAS WRONG BUT IT USES THAT MUCH.
29 Sep 2009 20:35 #324712 by MBFMGP
THANKS FOR THE TIP.
PULLED THE AIR FILTER AND WHILE IT HAD OIL ON IT IT WASN'T SOAKED. ALSO THE TUBE GOING INTO IT WAS CLEAR.
WHERES THE VENT?
29 Sep 2009 20:37 #324713 by PLUMMEN
follow the tube down to the engine to find the vent B)
29 Sep 2009 22:34 #324724 by bountyhunter
Replied by bountyhunter on topic HIGH OIL CONSUMPTION
No way valve guides can leak that much. I would think if your rings were that bad, you should make blue smoke like a cropduster when you open the throttle to accelerate. Somebody behind you should be able to see your vapor trail. I'm not laughing, I had a 1970 plymouth that burned a quart every 300 miles. It's possible.
30 Sep 2009 02:43 #324737 by chance
I had a bike that the floats were to high letting gas into my cly passing the rings thining my oil thus it was useing about the same has yours.I set the float level and changed the oil and the problem was solved. I don't think thats your problem but something to consider. My bike hardley smoked too.
30 Sep 2009 05:30 #324747 by Old Man Rock
Replied by Old Man Rock on topic HIGH OIL CONSUMPTION
On a motor that holds what ~ 4 quarts of oil, that's a huge amount of oil in 200 miles... :blink:
As mentioned, compression test, leak down test, oil pressure measurement etc....
I'm with the others, if it isn't smoking like a banshee, it isn't draining into the air filter enclosure/tube clear, no cylinder/head oil gasket leakage, plugs not fouled/saturated in oil, no oil at the end of the exhaust etc... then it has to be dripping out somewhere below unnoticed...... such as crack in the oil pan or lower engine case, oil filter gasket leaking etc...
Wash her clean, insure oil at proper level, jack the rear up on the center stand, cooling fan aimed on the motor, start her up and find the leak...
There's no way you can possibly be burning that much oil with no exhaust smoke or other mentioned variables in 200 miles... maybe we're all wrong but at least extremely unlikely to be burning that much.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
