'81 KZ650 Surging / cutting off when hot
- TriniTT
I'm fairly confident in my mechanical abilities. It only took about 2 hours to replace the piston rings and have her running again. I'm pretty sure I'm capable of measuring the valve bucket clearances
I just found the numbers I think, it says .08-.18mm. Does that sound right?
- PLUMMEN
- Thank you received: 104
- BSKZ650
- Thank you received: 14
it sounds kind of like a fuel delivery issue rather than mech.
77 ltd1000, current rider
76 kz900, just waiting
- OKC_Kent
- Thank you received: 20
"...but I was just replacing the piston rings at the time and I wanted to get everything back together. It's not hard to take this motor apart, so I may go ahead and order new valve seals and install them just to be certain."
Yes that is the measurement.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- TriniTT
As I mentioned at the beginning, I replaced the rings, "and I'm now making decent compression again." Suffice it to say, if I have the common sense to tear apart an engine, it's likely I also had the common sense to make sure I had a reason first
My compression is decent now since I replaced the pistons and used a different cylinder head. I was making 30-60-90-70 before, and it jumped up a bit when I poured oil down the cylinder. Since I changed the piston rings and have driven it a bit, it's up to 120psi across them all. This is just to clarify on the background as to what I've tackled thus far, which is what led me to the valve stem seals.
The smoke I'm seeing right now is bluish-white, and looks and smells like oil smoke. Thus, I'm replacing the valve seals.
Now another issue I just noticed after a brief drive today is the float bowl overflow lines are periodically dumping fuel out, and quite a bit at that. I was checking out my battery issue (yeah, can't seem to keep it charged either, despite good readings from the alternator and a solid connection to the battery and grounds), and I noticed a puddle forming under the bike. I looked up and it was just dumping fuel out of those lines, but only for a second or two, then it stopped and started again a few seconds later.
- grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- TriniTT
To clarify the issue with the fuel, it appears to only be pouring from the #4 bowl. I know the cylinder is firing, however, because if I block the intake pod for that carb, the engine dies.
Wouldn't fuel overflowing from the float bowls mean there was too much fuel? If it's not getting enough fuel, how would the bowls be overflowing? Clearly the bowl is getting too much fuel, and thus is overflowing. Now, I've seen a few pics of the vacuum lines, but just to clarify:
In the pic, the brown tubing is venting to the back/atmosphere, as pictured. The fuel line labeled goes to the fuel part of the petcock, and the vacuum goes to the vacuum of the petcock. The only thing I don't see pictured are 2 lines on the back of the carbs (I believe #1 and #4 each have one) that have been blocked off with a bolt in the vacuum line. Is this all correct?
- JMKZHI
- Thank you received: 48
As for the fuel level, do the Servce Fuel Level Check by removing the carbs from the bike, rigging up an auxilliary supply of fuel, then check the fuel level in each carb. Do so by connecting clear tubing to the overflow nipple at the bottom of the carb, hold it up high & against the carb body, then opening the drain screw. Fuel should flow into the tubing. Lower the tubing & hold it at the lower level & note the fuel level again. It should be 3mm +/- 1mm below the carb body (or 1/8"). If you raise the tubing, start over.The fuel petcock is switched to "on" at all times.
Wouldn't fuel overflow from the float bowls mean there was too much fuel? If it's not getting enough fuel, how would the bowls be overflowing? Clearly the bowls are getting too much fuel, and thus are overflowing....
...The only thing I don't see pictured are 2 lines on the back of the carbs (I believe #1 and #4 each have one) that have been blocked off with a bolt in the vacuum line. Is this all correct?
As for those other ports, do you mean the engine side of the carbs? And are they actually on the carbs? Or are they the nipples on the carb holders - if so, two of those normaly have the air induction system tubing, while the other two are capped. Some folks remove the air induction system (smog device) & cap the ports.
- TriniTT
- JMKZHI
And it wouldn't hurt to replace the other two on #2 & #3.
Z1Enterprises.com sells them as well. By the way, I sent you a private message.
- TriniTT
