'81 KZ650 Surging / cutting off when hot
- TriniTT
My issue now is this: when I get it running, it surges (seems kinda sluggish when I roll on the throttle, then takes off like a crazy machine). I've read about this issue on this site, but I've never seen anyone say what causes this.
Now, about the bike (sorry, still learning about terms, parts, etc.). My kz has a 4-1 exhaust straight through (no muffler). It also has pods, which I've read aren't helping me. I purchased an airbox to replace them, which hopefully will be here within a few days.
When I ride the bike, it will go for a few minute, but if I shut it off or just stop, it will die and won't restart. I took apart the carbs and cleaned the pilot/jets out and everything seemed clean. When I bought the bike, I was told the jets were tuned for the current setup, but I don't know how to verify this.
I've checked my sparks, and I'm getting good spark all around. I have new plugs, and my coils are functioning properly.
Any suggestions on the surging and rough hot start are much appreciated. Thanks!
Jonnie
- JMKZHI
- Thank you received: 48
If you bought a KZ650-CSR airbox, I hope some good airbox ducts are included (the ones for the 81 650-CSR are no longer available).....I purchased an airbox to replace them, which hopefully will be here within a few days....
Does the bike have the stock VM24 carbs w/ accelerator pump?
You can verify the main jets by removing them & looking for a number stamped on them - stock is 92.5, your setup will need several sizes bigger. There's probably a way to see what size the pilot jets are - you could pull those out & take a look at them. Maybe go to a carb parts site or Z1Enterprises.com for info. I'm fairly sure the CSR VM carbs don't have slots on the jet needles for clips, but I guess you can check to see if there's a shim somewhere to see if they have been raised.
- TriniTT
I didn't notice any numbers on the carbs, but I also wasn't looking. Also, I'm not sure what the reference to "jet needle clips" is to, because I don't recall there being any clips on the jet needles. However, I only removed the jets themselves, and not the needles, so I didn't get that deep into the carb.
I'm considering taking the carbs to a pro, but there aren't any local shops so I'll have to scout one out.
- JMKZHI
Carb ID. If the carb tops have 3 screws, then they're probably the stock VM24 carbs. WGCarbs.com should have some photos to help you identify your carbs. Or you could use the diagrams at Kawasaki.com.
- loudhvx
- Thank you received: 1616
When the engine warms up, the valve stems grow longer and the valves stop sealing if there is insufficient gap where the cams press down on them.
After just a few minutes, or even seconds, of cooling, the valves will seal again.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- TriniTT
When I looked at the valves, they looked like they could use new seals, but I was just replacing the piston rings at the time and I wanted to get everything back together. It's not hard to take this motor apart, so I may go ahead and order new valve seals and install them just to be certain.
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- TriniTT
- JMKZHI
- TriniTT
I looked in the service manual, and I can't find any place where it says the distance I need to measure b/t the cam lobe when it's facing away from the valve and the valve bowl cover. I see a lot of other valve measurements, but I can't seem to find that one. Any suggestions?
- JMKZHI
- loudhvx
I don't know what level of mechanic you are, but that's not entirely a job for a first time mechanic. Checking the valve clearance is fine, but actually adjusting the clearance is a lot more involved. You have to remove the cams, sprockets, buckets, chain-tensioner etc. You have to be able to time the valve train on the engine. It should all be in the manual, and as long as you are very very patient and follow every step, it's not a big deal. Any rushing and it's very easy to make engine-life-ending mistakes. Plan on taking a day or two if they need adjustment, and make sure you have a very clean, organized work environment. Actually if it needs adjustment, you'll probably have to order some shims.
The reason they make it so difficult is to reduce the valve train to the minimum number of moving parts. It's also one of the most reliable valve trains ever designed from that era. But service is definitely a big job for someone new to it all.
1981 KZ550 D1 gpz.
Other links.
