oil cooler size.
- kzrider4life
oil cooler size.
22 Sep 2009 15:26
what is the right size for a oil cooler for a kz1000? I have the fittings and hose am want to buy a cooler but want to get the right size. I dont want a monster or a tiny one, thoughts?
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
- chance
- Life long biker/
- Old Man Rock
Re: oil cooler size.
22 Sep 2009 17:17
GPZ-1100, 3 to 5 row small cooler....
Pending where you live, 7 row should be more than efficient...
OMR
Here's a couple links to Earls Coolers... NEW!
www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
www.nextag.com/earls-oil-cooler/stores-html
Engine Oil Cooler Adapters...
americanclassix.com/streetfighter_conversions.html
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- IowaKZ
- '80 G1 Classic
22 Sep 2009 17:31
does anyone have a good pic showing where the oil cooler lines attach?
1980 G1 Classic
Bettendorf, Iowa
Bettendorf, Iowa
- BohicaBob
22 Sep 2009 18:02
I use
12-row JC Whitney oil cooler
on my '73 Z1-900. It works very well with a Lockhart BP-180 oil thermostat.
- Old Man Rock
22 Sep 2009 18:09 - 22 Sep 2009 18:10
@ BohicaBob...
12 row, nice unit... Seems Narrow but ong in the width...
You have any images of that installed....
Assuming above the header mounts on the frame.?
What about the oil line adapters, AmericanClassix or some other?
Thanks,
OMR
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 22 Sep 2009 18:10 by Old Man Rock.
- cruspeed
22 Sep 2009 19:43 - 22 Sep 2009 19:44
One of the good things about the Advance-Design cooler in BohicaBobs post is it has 1/2" NPT threads, you can use regular 1/2" NPT hose fittings from any hardware store and use some hydralic hose from the car store to get it set up. You can also go high speed and use swagelok fittings and get some stainless tubing and bend it up with a hand held bender and make it look seamless and completly custom for around $100 to $150 depending on where you get your swageloks and tube.
78 KZ1000 project X 2
Last edit: 22 Sep 2009 19:44 by cruspeed. Reason: npt ntp......
- Kawickrice
22 Sep 2009 19:58
There is a good write up about oil cooler fabrication and making your own adapters to plumb it in. Click on oil cooler fabrication on the left side of the page. Its a pretty good read check it out.
www.oldkawman.com/
www.oldkawman.com/
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
22 Sep 2009 20:14
But what a hob nob job if you ask me.... :blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
22 Sep 2009 20:37 - 22 Sep 2009 20:39
Old Man Rock wrote:
Probably just needs a little more silicone! :laugh: :laugh:
Last edit: 22 Sep 2009 20:39 by Patton.
- Kawickrice
22 Sep 2009 20:56
Yea he is not in it for show thats for sure. I thought the homemade fitting was fairly simple to make. His choice of hoses and gauge setup is redneck as hell, but some braided line and a few mods would do the trick.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kzrider4life
22 Sep 2009 21:50
cruspeed wrote:
Any pics of the stainless tubing idea mounted?
