oil cooler size.
- chance
- Life long biker/
- kawboy13
Re: oil cooler size.
23 Sep 2009 11:26
I used that same 12 row cooler on my 78 1000 ltd but trimmed the flanges and made some small brkts to mount it. I wanted to keep the stock oil light so I tapped the fitting ( oil sending unit? ) for 1/2" hose barb and then used an epoxy to block the inlet and outlet connection on the send. unit. I had to drill and tap a new hole in the unit but had to reduce to 3/8" fitting because of the wall thickness.
- PLUMMEN
23 Sep 2009 11:46
chance wrote:
that seems to be par for the course for everything of his ive ever seen! :laugh: personally i wouldnt have this guy build a motor for a lawnmower,let alone a bike but thats just me !
- racer54
23 Sep 2009 13:57
You're just jealous you can't get ahold of that much silicone!!!
- kzrider4life
23 Sep 2009 19:16
Anyone have pics of hardlines ran to a oil cooler?
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
- cruspeed
24 Sep 2009 01:08 - 24 Sep 2009 01:11
kzrider4life wrote:
My bikes are both torn down getting painted for a rebuild but I used the 12 row cooler and 3/8" 304 stainless tubing. You can get it from Onlinemetals.com, 2 5' sections are about $35 total, 1/2" is to large to bend tight enough. Just follow the swagelok instructions, it's finger tight then mark it and spin 1.25 turns. We use them alot here at work for transfering solvents and pressure them up to 35 PsiG and have never had one blow off, rupture or leak and you can get them on the major online auction site for about $10 for a set.
A normal person could put there bike together in a few weeks, will take me 3 months so if you can wait that long I'll post up some pictures.
www.onlinemetals.com/merchant.cfm?pid=14...hes&id=312&top_cat=1
Any pics of the stainless tubing idea mounted?
78 KZ1000 project X 2
Last edit: 24 Sep 2009 01:11 by cruspeed.
- BohicaBob
- Old Man Rock
24 Sep 2009 19:23
AH-sooooo.... Yup, figured that was how'd you have it mounted...
BTW, white, black and buffed aluminum looks might purdy... The color matching flows beautifully... Sweet!
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
