- Thank you received: 337
what is the optimal oil temp?
- bountyhunter
22 Sep 2009 13:30 - 22 Sep 2009 13:32 #323267
by bountyhunter
Replied by bountyhunter on topic what is the optimal oil temp?
TexasKZ wrote:
Most coolers feed a parallel path where a small amount of oil flow is "bled off" the main output of the pump and circulated through the cooler and returns to the pan. About an extra quart of oil runs the "outside" loop.
Just curious here, how will the supply line be plumbed so that when the thermostat is nearly closed, the engine does not starve for oil?
Last edit: 22 Sep 2009 13:32 by bountyhunter.
- kawsakiman
- Thank you received: 6
22 Sep 2009 17:29 #323327
by kawsakiman
Replied by kawsakiman on topic what is the optimal oil temp?
- Old Man Rock
- Thank you received: 225
22 Sep 2009 18:45 #323366
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic what is the optimal oil temp?
Pretty good deal for $150, includes adapters as well.... Sweet!
Good job Stevie!
Good job Stevie!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- hardr0ck68
- Who put the what in the where?
22 Sep 2009 20:09 #323392
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic what is the optimal oil temp?
Fittings! I don't need no stinking fittings!!
Thanks for the heads up, but I scored a gpz oil pan on a $19 BIN about a month back. I have a gpz oil cooler and lines also from an e-bay purchase awhile back.
I plan on using the fittings off of the gpz hoses and making my own stainless hoses (everyone likes the look of braided steel lines right?)
The only think I am missing is the thermostat...
1977 kz650 c1
- Thank you received: 2098
22 Sep 2009 20:46 - 22 Sep 2009 20:47 #323412
by Patton
Replied by Patton on topic what is the optimal oil temp?
hardr0ck68 wrote:
If not already considered, must route braided steel lines very carefully to avoid abrading painted surfaces or other finishes.
Good Luck!
...I plan on using the fittings off of the gpz hoses and making my own stainless hoses (everyone likes the look of braided steel lines right?)....
Good Luck!
Last edit: 22 Sep 2009 20:47 by Patton.
- hardr0ck68
22 Sep 2009 20:59 - 22 Sep 2009 21:04 #323414
by hardr0ck68
1977 kz650 c1
A trick I picked up when building paintball gear, we did not want to ruin our $1000 anodizing work so we would put shrink wrap on the braided steel lines... you could even get clear shrink wrap (which is what I would do here).
bugger link didn't work so no paintball gun pic to show you, but yeah some of the ano that folks do is intense and expensive. Scratches from braided steel lines are not appreciated.
1977 kz650 c1
Last edit: 22 Sep 2009 21:04 by hardr0ck68.
- kawsakiman
22 Sep 2009 22:14 #323430
by kawsakiman
might be time for you to pick up the phone and call the local kz god in the rochester area.
pm me for his phone number or click on the link in my signature and call him yourself.
btw, i invite everyone to check the sight out.
at bare minimun, there are some kick ass pictures there.
