what is the optimal oil temp?
- hardr0ck68
- Who put the what in the where?
20 Sep 2009 16:43
If I were to put an oil cooler on my bike, with a thermostat what heat range should I look for?
What temp do I want to keep the oil at?
If there is any information you folks can point me to about this topic please pass it along.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- PLUMMEN
Re: what is the optimal oil temp?
20 Sep 2009 16:47
im gonna say between 180-220 is gonna be in the ballpark on an aircooled motor depending on where you live.im gonna guess an oil cooler would drop it 10-20 degrees depending on how big it is and how fast air is moving over it
- MFolks
20 Sep 2009 16:51
Water boils at 212 F so you'd want your oil to be hotter than that to "burn off the moisture" but not enough to suffer thermal breakdown.
I'd check with the engine building people as to what oil cooler might possibly be needed. This all depends on what part of the country your talking about and weight of oil.
I think Jeff Saunders when he gets a bike with an oil cooler is the first thing he removes.
Some engine rebuilders:
www.aperaceparts.com
www.bore-tech.com
www.flowbenchtech.com
www.fastbygast.com
www.grccranks.com
www.schnitzracing.com
www.valleyspeed.ca/services.html
www.bore-tech.com
www.fastbygast.com
www.grccranks.com
- hardr0ck68
20 Sep 2009 17:31
I know an oil cooler is not a good idea for a stock motor, as it can over cool the motor. However I will be fitting a gpz oil pan and cooler soon, I was going to make new oil lines and include a thermostat with oil bypass to keep the temp correct.
I am not sure if I will be adding the 810 kit this winter or instead having the head re-done. I asked LarryC what he recommended as the order of events (810 kit and ride it a year and a stock 750 head, or get the head done this winter then go 810 next winter) he never really gave me an answer... so I think I will send an e-mail to ape and see what they recommend.
the point is, that one day fairly soon this motor will probably need the extra cooling; and even if it does not need the oil cooler a thermostat set for the proper temperature will keep the oil in a specified heat range.
That is why I want to know what heat range to look for.
1977 kz650 c1
- bountyhunter
20 Sep 2009 22:39 - 20 Sep 2009 22:40
hardr0ck68 wrote:
The thermostat should prevent that.I know an oil cooler is not a good idea for a stock motor, as it can over cool the motor.
Last edit: 20 Sep 2009 22:40 by bountyhunter.
- hardr0ck68
21 Sep 2009 09:03
Ok Mocal makes 2 different oil thermostats the ot1 and the ot2, and they both offer 2 different heat ranges.
I am unsure of which model I will chose, probably the ot1 as it is about half the price.
Now they offer both in 180* and 203* temps, so the cooler goes from part open (they say the thermostat never fully shuts off flow to the oil cooler) to full open at either 180* or 203*
Hearing from you folks I am tempted to go for the high temp thermostat...
Any other folks have wisdom to offer up? I could certainly use it!
1977 kz650 c1
21 Sep 2009 14:20
Just curious here, how will the supply line be plumbed so that when the thermostat is nearly closed, the engine does not starve for oil?
- hardr0ck68
21 Sep 2009 18:18
Some info
97.74.103.94/files/thermos$.pdf?Submit1=Get+Pricing
www.theflyingbanana.com/oil-cooler.htm
both good reads and full of info.
1977 kz650 c1
- hardr0ck68
21 Sep 2009 18:27
hurm, well the first link seems to be bunk,
ok go here
www.batinc.net/thermos.htm
scroll down and click "get pricing" there are some great pictures and information in that link.
ok go here
1977 kz650 c1
- TeK9iNe
- What did you do!?!
21 Sep 2009 21:04
Personally, I wouldnt use a thermostat. I've seen it create strange problems.
You get riding along and the bike starts to get hot then blam, the thermostat opens and all that super cold oil from your last ride smashes into your engine super fast.
This would make my friends bike have wacky power issues. Took forever to figure that one out...
We tossed the thermostat and ran it without. Had to use a rad cover to get the bike up to 220+f. Then just open the rad cover and ride on...
use a nice oil cap thermometer. www.americanclassix.com/kawa_improvements.html
Made the bike alot more predictable.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hardr0ck68
22 Sep 2009 09:41
according the the manufacturer that is why the thermostat never fully closes off the oil cooler, to get the oil in the oil cooler up to temp as well and prevent thermo-shock when it does open.
When I read those claims I thought thermo-shock surrreee, yeah right; but apparently it is a concern, but a concern this company has apparently designed for.
Thanks for letting me know this thermostat is better than I thought!!
1977 kz650 c1
- TeK9iNe
22 Sep 2009 12:28 - 22 Sep 2009 12:31
hardr0ck68 wrote:
Right... That makes sense. The one I took out of my friends bike was really old and probally sticking. It made such a huge difference without it...
The oil thermometer should be a priority purchase for anybody changing carburetion/modding thier bikes!! :laugh:
Cheers.
PS. I read somewhere that temps should reach at least 200f, but never over 250f. Sounds ok to me...
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 22 Sep 2009 12:31 by TeK9iNe.
